Rear tub part numbers
Old Mar 30, 2005 | 05:23 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Rear tub part numbers
Anybody have the part number for the lower and upper rear tub?
Old Mar 30, 2005 | 10:14 PM
Jeffvette's Avatar
Jeffvette
Nobody?
Old Mar 30, 2005 | 10:16 PM
leaftye's Avatar
leaftye
Ouch, that don't look good! There's a parts catalog (pdf - 50 megs) on the C5 downloads section of www.crossedflags.com. Good reference to have for all part # questions.
Old Mar 30, 2005 | 10:41 PM
Jeffvette's Avatar
Jeffvette
Thanks, never seen that site. It's not as bad as it looks.
Old Mar 31, 2005 | 10:23 AM
SpeedyZ's Avatar
SpeedyZ
Ouch!!! Been there, doing that now.... Here is numbers for 2001 Z06 FRC, you will need different tub top for a coupe. The part numbers in the PDF everyone has for download are old and a lot of them has changed. Good luck with the project!
PS: Don't forget to install mini tubs while your in there, it's easy while everything is all apart! I actually used the wheel wells from my old busted tub (looked about like yours) to maxi-tub my new replacement tub. PM me for details.
89022391 Rear Tub (old number 12455603)
10336691 Rear compartment frame FRC (tub top) (old # 10269095)
12533362 Rear Impact Bar (frame)
10433081 Rear Fascia (Rear Cover)
10230344 Rear Fascia Absorber
10277215 Rear Fascia Absorber spacer
16523537 Backup Lamp and Lic Plt holder
10253893 Third Brake Light
16524722 Rear Side Marker Lamps
To Rear tub part numbers
