billy boat exhaust installation
Old Apr 1, 2005 | 02:22 PM
2vetteguy's Avatar
2vetteguy
Default billy boat exhaust installation
i have a kwiklift and wonder if anyone else out there has changed an exhaust (converter and over axle pipes) on a kwiklift and if so any special things to do? i would rather not cut the stock exhaust off if possible
Old Apr 1, 2005 | 04:28 PM
c5krazy's Avatar
c5krazy
i have installed a b&b prt on my 04 using the quicklift. there is not quite enough room to remove without cutting so i had to use a floor jack to raise each corner a few inches so i could remove intact. great inexpensive lift.
Old Apr 1, 2005 | 05:11 PM
One Blue Vette's Avatar
One Blue Vette
What is a quick lift?
How high do you have to go to get the stock pipes off with out cutting?
Old Apr 1, 2005 | 05:54 PM
Rob 2K1's Avatar
Rob 2K1
The back needs to be about 36" off the ground.
Old Apr 1, 2005 | 11:53 PM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
Check out this post with pictures. He did it without cutting on a kwiklift. Good luck.
http://forums.corvetteforum.com/show....php?t=1052710
Jim Kay
To billy boat exhaust installation
