160 ft-lbs ?!!?!?!
Old Apr 1, 2005 | 07:29 PM
yellow01's Avatar
yellow01
Default 160 ft-lbs ?!!?!?!
First - I had no idea where this should go but it's about a c5 so here it is...
I'm putting in my Bilsteins tomorrow, my current torque wrench will not get near the 160 ft-lbs needed for the rear lower bolts.
The biggest Sears Craftsman model only goes to 150.
What do you DIY'ers use? or, dare I say, is 150 ok?
TIA
Old Apr 1, 2005 | 07:33 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
close enough with a tiny tug for 10 lb.
Old Apr 1, 2005 | 07:37 PM
happa's Avatar
happa
try napa auto parts. they have a good selection of torque wrenches. Good Luck
Old Apr 1, 2005 | 07:41 PM
yellow01's Avatar
yellow01
Yah, that's kinda what I was thinking but didn't want to do anything dumb. I'm all over the 45 ft-lb stuff...just wasn't sure about the heavy metal
Old Apr 1, 2005 | 07:42 PM
happa's Avatar
happa
try napa auto parts store. they have a good selection of torque wrenches. Good Luck!
Old Apr 1, 2005 | 10:28 PM
LoneStarFRC's Avatar
LoneStarFRC
Eat yer Wheaties!
Old Apr 1, 2005 | 11:30 PM
xlr8shn's Avatar
xlr8shn
Hrm, my craftsman 1/2" drive digitorque torque wrench goes that high...
Just used it today to torque the brake mount bolts to 175 NM and the lower rear shock bolts to 220 NM and the right rear axle nut to 160 NM...
Old Apr 2, 2005 | 12:35 AM
Vette#2's Avatar
Vette#2
It's great to see that somebody know that some Dodge Rams are built in Mexico by $1.80 per hour nonunion labor.
I work for DCX Warren & we stamp many of the [DR] Dodge Ram compents & ship them to St.Louis North & mexico.
Old Apr 2, 2005 | 01:40 AM
allanlaw's Avatar
allanlaw
We just crank it till it's tight . . . .
Old Apr 2, 2005 | 04:16 AM
RonnieLS1's Avatar
RonnieLS1
Just installed Bilsteins. Broke the drivers side bolt at 140 FT LBS.
Old Apr 2, 2005 | 05:05 AM
Shylor's Avatar
Shylor
Didn't someone say the 160ft/lb torque was incorrect in the service manuals?
Old Apr 2, 2005 | 05:49 AM
John Shiels
Wonder why the Mexican Dodges aren't cheaper? I went to buy or look at a Ford F-750. Made in Mexico they can jamb that too. I am proud of Kentucy sticker on the Excursion and the St. Louis sticker on the Dodge. I guess Ford Super Duty, GM or walk if it isn't made here. Like Chevy "The AmericanRevolution" Equinox with a Chinese motor. I look at everything I purchase down to nails.
Old Apr 2, 2005 | 07:27 AM
yellow01's Avatar
yellow01
hmm, 220nm = 162ft-lbs...which model? Maybe I should return it and get another.
Did you try and reuse the bolts? I heard they're one time use so I got some new ones sitting in wait
Uh-oh...anyone know for sure?
Old Apr 2, 2005 | 07:43 AM
David426's Avatar
David426
My engine puts out about 370 ft-lbs of torque
Old Apr 2, 2005 | 07:52 AM
yellow01's Avatar
yellow01
Do you have a socket adapter that will fit a 1/2" drive?
Old Apr 2, 2005 | 08:00 PM
Shylor's Avatar
Shylor
I could have swore there was a thread about this saying the torque of 160ft/lbs was way to much. It sure seems like to much to me, for shock bolts.
Old Apr 2, 2005 | 08:27 PM
97vettec5's Avatar
97vettec5
in my service manual it says exactly 162 lb ft
Old Apr 2, 2005 | 09:31 PM
Shylor's Avatar
Shylor
I know what the manual says. But as I stated, I thought someone said the manual's printed torque number was incorrect.
Old Apr 3, 2005 | 08:43 AM
yellow01's Avatar
yellow01
I'm with you - It seems like alot considering the front mounts are in the 20's.
The only thing I can think of is in back, the bolt bears the load placed on the shock, whereas in front the A-arm contacts the shock directly, and the bolts simply fasten to the A-arm.
So, since the bolt in back must bear the load, it must be big, and it is BIG, and as a result may require a larger torque value to stay put (bolt with a significantly larger radius would require more torque to apply a similar force on the threads).
To 160 ft-lbs ?!!?!?!
