Tach signal wire?
Knowing my luck I won't get the right wire until the 5th or 6th try (yes, I know there are only 4 white wires to pick from...)
I USED THE QUICK SPLICE BLUE CONECTORS YOU CAN BUY FROM ANY AUTO PARTS STORE AND USED A TEST LIGHT ON THE METAL SPLICER IN THE CONECTER WHEN I HIT THE TACH WIRE THE NEEDLE JUMPS UP THEN GOES TO ZERO. THE OTHER WIRES WILL TRIGGER SKIP LIGHT AND HUD LIGHT. SEE POST ABOVE ABOUT SKIP LIGHT DELETE.
