Ehaust tip installation
Old Apr 2, 2005 | 08:16 AM
cajung's Avatar
cajung
Default Ehaust tip installation
Good morning everyone. I'm just looking for a little advice. I purchased 4 chrome exhaust tips on Ebay for my 97 Vette. The auction stated that they just slip on and nothing else is needed for installation (I guess they fit on very snugly). They have no hold-on clamps on the inside like some that I have seen have. I really don't want to drill and use a sheet metal screw. I was thinking of using a small dab of JB WELD. Do you think this will do the job? Thanks, Craig
Old Apr 2, 2005 | 09:25 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
before i got the Corsa Indys I had the corsa tips on my stock exhaust, they just slipped on but also had a sheet metal screw on the bottom .
it was no problem drilling the screw hole, even with the tips off you couldn't see the hole for the screw.
you should use the screw, you don't want to loose one of the tips.
JB weld is great stuff, but you never know what the vibration and heat from the exhaust will do to it.
Old Apr 2, 2005 | 09:31 AM
EHS's Avatar
EHS
Good luck with those. Literally.
I had them on mine. Here's a review from waaayyyy back, before I knew better:
http://forums.corvetteforum.com/revi...&cat=15&page=1
Old Apr 2, 2005 | 10:01 AM
cajung's Avatar
cajung
EHS...I don't believe these are the same tips that I have. Mine have no clips on them.
Old Apr 2, 2005 | 11:52 AM
66427-450's Avatar
66427-450
if they're the factory type/shape, just a tack weld in the notch, if you don't have a welder, any muffler shop can do it in a couple seconds ........ the BJ weld would work, but i'd weld
Old Apr 2, 2005 | 12:52 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Screw welding. I'd just stick a tiny screw through the clamp.
Old Apr 2, 2005 | 01:31 PM
cajung's Avatar
cajung
Thanks everyone for all your advice. I decided to try using JB WELD. I'm hoping that will do the trick. I'll check the tips every now and then to see if they are loosening. I'm hoping the JB Weld will work, but if I end up losing one on the road, I'll see if I can purchase a replacement.
To Ehaust tip installation
