Service Tire Mon Sys HELP NEEDED!!
Old Apr 2, 2005 | 10:47 PM
doyle2864's Avatar
doyle2864
Cruising
Default Service Tire Mon Sys HELP NEEDED!!
I have a '99 and I need help to reset the computer. It keeps telling me to service the tire monitor system. I think the dealer may have ruined my sensor in my passenger front tire. Is there a way I can stop the message from coming up? I check my tire pressure about once a week and it's fine. Thanks for any help. Annette
Old Apr 2, 2005 | 10:55 PM
Special K's Avatar
Special K
If he broke it, make him fix it. Then it will go away.
Bob
Old Apr 2, 2005 | 10:57 PM
happa's Avatar
happa
Its probley your sensor, mines doing the same thing. I cant replace it till i get new tires or my new rims. Mine was messed up by a pothole Bob at houseofwheelsonline.com has them a lot cheaper then a dealer or anyone else. good luck
Old Apr 3, 2005 | 07:21 AM
RCK1999's Avatar
RCK1999
No, unfortunately for your model year there is no way to disable the tire pressure monitoring system. You will continue to get error messages until you fix the problem.
Old Apr 3, 2005 | 07:46 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
well not 100% true....Tech2 will turn it off
Old Apr 3, 2005 | 07:51 AM
RCK1999's Avatar
RCK1999
You can only turn it off in '01 and newer. Won't work in '97-'00. It This update to the BCM was rolled out when the Z06's were introduced in '01. As they don't run the TPM system but use the same BCM, the option to de-activate was needed.
Old Apr 3, 2005 | 08:44 AM
pewter99's Avatar
pewter99
hmmmm I have been told by several people they could turn mine off with Tech 2.....oh well...mine is only intermittent anyway which is funny since I don't have TPS it didnt even come on for 90 days after I took them out
Old Apr 3, 2005 | 09:12 AM
RCK1999's Avatar
RCK1999
I guess that's why whenever we name our cars, we always give them female names. Finicky, illogical, inpredicatble, and defying explanation. Sometimes signals get lost or mis-understood.
Hope the weather is good over there. Its looking great here, so Yvette & I are heading out!
PS - Pewter '99s rule!
Old Apr 3, 2005 | 10:08 AM
doyle2864's Avatar
doyle2864
Cruising
They insisted they didn't do it. Funny never came on till I brought it there. Thanks!
Old Apr 3, 2005 | 03:02 PM
doyle2864's Avatar
doyle2864
Cruising
Thanks everyone for the input!!
To Service Tire Mon Sys HELP NEEDED!!
