New A4 fluid Dexron-4
Old Apr 3, 2005 | 05:54 PM
2000Firehawk's Avatar
2000Firehawk
Default New A4 fluid Dexron-4
NEW GM FLUID for 2006
FOR RELEASE: 2005-04-01
GM Introduces New Automatic Transmission Fluid For 2006 Cars and Trucks
New factory-fill fluid standard in all 2006 MY Hydra-Matic transmissions
Significantly improved viscosity, shift performance and fluid durability
Available through GM Vehicle Care products as DEXRON®-VI
Approved for service application on all prior model year Hydra-Matic automatic transmissions
Pontiac, Mich. - GM, in conjunction with Petro-Canada and Afton Chemical Corporation, have developed a new, improved automatic transmission fluid for all 2006 model year Hydra-Matic automatic transmissions. Developed for factory-fill as RDL-3434 and registered for service fill as DEXRON®-VI, the new fluid represents a significant improvement in automatic transmission fluids and is the direct result of GM's industry leadership in the development and production of automatic transmissions.
"For 65 years, GM has led in the design, development and production of automatic transmissions," says Tom Stephens, group vice president for GM Powertrain. "This knowledge and experience has helped us work directly with the petroleum industry to develop a new fluid that will further accentuate the performance and reliability of GM's Hydra-Matic transmissions."
Automatic transmission fluid (ATF) is considered the life-blood of the automatic transmission. It is used to transfer power in the torque converter and provide the pressure to apply the transmission's various clutches and bands. It also is used to clean, lubricate and cool the components of the transmission. GM's new transmission fluid, DEXRON®-VI, was developed to have a more consistent viscosity profile; a more consistent shift performance in extreme conditions; and less degradation over time.
Beginning with the design and development of GM's new Hydra-Matic 6-speed rear-wheel-drive transmissions, GM Powertrain engineers determined the need for a new transmission fluid to withstand the complexity of the clutch-to-clutch transmission operation. Additionally, GM engineers identified opportunities to improve viscosity, durability, and impact on fuel economy with a new fluid.
"The development of DEXRON®-VI is the first time an automotive company has worked so closely with petroleum and additive companies to develop a new fluid," says Roy Fewkes, driveline fluids group leader, GM Powertrain. "The result is a new fluid that significantly outperforms existing fluids in every aspect. In fact, we have had to significantly extend the length of our durability tests to fully test the fluid's capability."
Internal GM tests have demonstrated DEXRON®-VI to deliver more than twice the durability and stability in friction tests compared to existing fluids. It also has demonstrated superior performance in pitting, foaming, oxidation and shear stability tests.
GM will begin factory-fill of the new transmission fluid on April 4, starting with the new Hydra-Matic 6L80, produced at the Willow Run transmission facility in Ypsilanti, Mich.
DEXRON®-VI will be available through genuine GM Vehicle Care products at GM authorized dealerships and service centers in Summer 2005.
General Motors Corp. (NYSE: GM), the world's largest automaker, has been the global industry sales leader since 1931. Founded in 1908, GM today employs about 324,000 people around the world. It has manufacturing operations in 32 countries and its vehicles are sold in 200 countries. In 2004, GM sold nearly 9 million cars and trucks globally, up 4 percent and the second-highest total in the company's history. GM's global headquarters are at the GM Renaissance Center in Detroit. More information on GM can be found at www.gm.com.
__________________
Old Apr 3, 2005 | 09:32 PM
leaftye's Avatar
leaftye
Thanks for the heads up!
Old Apr 3, 2005 | 10:54 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Vi = 6
Old Apr 4, 2005 | 06:13 AM
Vette_Fan's Avatar
Vette_Fan
Would anyone happen to know if this *new* AT trani fluid can be used in the C5s (A4) ????
Old Apr 4, 2005 | 09:01 AM
IMQUIK's Avatar
IMQUIK
Originally Posted by screw991le
Vi = 6
Hmmmm.. Remember it's GM.
Old Apr 4, 2005 | 12:13 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
Gm has always superceded the Dextron fluid and discontinued the older fluid. It should work better-Higher temperature usage.
Old Apr 4, 2005 | 04:08 PM
Dustie's Avatar
Dustie
Default ?
Popped into my GM dealer here in Georgetown today. Told him my car was ready for fluid change and I was interested in the new Dexron 4.... His response...
"Huh?'
I guess I'll give them a few months to "spool up".
Looks like a good product, hopefully make these expensive components last a good deal longer
Old Apr 4, 2005 | 08:26 PM
screw991le's Avatar
screw991le
It is Dexron 6 66666666666666666666666666666666
Not 4
I have no idea what happened to 4 and 5
Old Apr 10, 2005 | 07:33 AM
Vette_Fan's Avatar
Vette_Fan
Old Apr 10, 2005 | 04:56 PM
leaftye's Avatar
leaftye
It is Dexron 6
I = 1
II = 2
III = 3
IV = 4
V = 5
VI = 6
Old Apr 10, 2005 | 10:48 PM
cenzo's Avatar
cenzo
1 GM Introduces New Automatic Transmission Fluid For 2006 Cars and Trucks
Approved for service application on all prior model year Hydra-Matic automatic transmissions __________________
Old Apr 11, 2005 | 10:50 AM
screw991le's Avatar
screw991le
I am waiting for the local dealer to get it in, I am in need of a 5 year tranny flush. When they get the fluid in a few months I am getting it done.
To New A4 fluid Dexron-4
