Code P0530 - A/C does not work
Old Apr 4, 2005 | 01:54 PM
Day's Avatar
Day
Default Code P0530 - A/C does not work
A/C will work sometimes, but goes off. I checked the codes and have P0530. It is the Pressure sensor. Anybody every replace one of these? Can I bypass to test?
Old Apr 4, 2005 | 02:02 PM
ROD BROWN's Avatar
ROD BROWN
Default Bad A/C
Have you checked the coolant?You may be low and that will shut the A/C off.Do the lights on the A/C stay on or do they shut off?If the lights go off,I would bet you are low on coolant.Have the company check for leaks and do a service on the A/C.When is the last time you serviced your A/C?
Old Apr 4, 2005 | 02:05 PM
Day's Avatar
Day
The light goes out. Once in a while it stays on and it is cold. Ok, I got my baby in 01/01 and never had the A/C serviced...oops. Or good car!
To Code P0530 - A/C does not work
