lowering bolts,how much?
Old Apr 4, 2005 | 09:11 PM
vish2000's Avatar
vish2000
Default lowering bolts,how much?
while spring cleaning the wheel wells I noticed that the front bolts had only a few threads showing and the rear had about 1inch or more threads showing. is this normal ?
Old Apr 4, 2005 | 09:21 PM
happa's Avatar
happa
Yes and no. It depends on how low you want to go, Its not bad but if the car is low, look into a anlignment. cause my vette is slammed and I love it but I need a anlignment to save tires. So It might be a good height for you or loosen the rear to go lower and tighten the front to go lower.
Old Apr 4, 2005 | 09:22 PM
Dr. Dan's Avatar
Dr. Dan
Jack up at the crossmember and loosen the rear bolt so only 1 1/2 threads show. Then drive and stop it hard. Will settle everything down. You could then see if you want to go any more.
To lowering bolts,how much?
