Can I reuse catback gaskets???
Old Apr 6, 2005 | 01:37 PM
MHVette's Avatar
MHVette
Default Can I reuse catback gaskets???
I'm sure this question has been asked a thousand times but I couldn't find anything using the search...
Can I reuse the stock gaskets? I'm planning on installing a fairly new set of Z06 exhaust on my 2000 MN6 after work & my local Dealer doesn't have the gaskets in stock - & of course I'm to inpatient to wait. Also is it necessary to apply a high temp sealent on the gasket? If so what kind/brand... Thanks!
Old Apr 6, 2005 | 02:02 PM
white90conv's Avatar
white90conv
When I had my Z06 catbacks installed last week, they reused the old gaskets. I don't think there is likely to be a problem.
Old Apr 6, 2005 | 02:41 PM
mike348's Avatar
mike348
I put on ghls last month with 10000 miles on gaskets. They looked good so I reused them. I did not use any sealant on them.
Old Apr 6, 2005 | 02:42 PM
Avanti's Avatar
Avanti
You are fortunate in that the Z system seldom leaks, unlike some aftermarket, hence, you may get by. Try it, if the gaskets look good. It is easy to swap out later if one leaks.
All the best.
Old Apr 6, 2005 | 04:02 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
I've reused mine a couple times. You can use some high temp RTV Silicone sealant on them if you want. I use the Permatex Ultra Black about $4 a tube. I put a lil on mine last time. No leaks...
Just be careful when you remove them. You can use something like a razor blade to help if they stick...
Steve
Old Apr 6, 2005 | 04:45 PM
MHVette's Avatar
MHVette
Thanks for all the reply! I can't wait to get home and put them on
To Can I reuse catback gaskets???
