Stripped lowering bolt...
Old Apr 7, 2005 | 02:03 AM
RunNE1's Avatar
RunNE1
Default Stripped lowering bolt...
I decided to lower the car today. Lowering the rear went smoothly. The front, was another story. Had a hell of a time with the passenger side stud and then wound up stripping it. The driver side was much easier to adjust. Is there a way to replace the stud? Do I just vice-grip it to where I need it? Thanks for the help.
Old Apr 7, 2005 | 02:23 AM
RainJ's Avatar
RainJ
From: Biloxi MS Theres something happenin' here, What it is ain't exactly clear.....
you rounded off the bolt head?
Old Apr 7, 2005 | 07:35 AM
RunNE1's Avatar
RunNE1
Sorry, yes I rounded off the headbolt. I guess stripped was the wrong term.
Old Apr 7, 2005 | 07:44 AM
Quacker's Avatar
Quacker
Not long ago someone posted where to get replacement bolts from but I can't find it. I'm sure they will jump in with the info.
Old Apr 7, 2005 | 07:48 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Depends how "rounded" it really is - You could go the vice grip route to get it where you want - but you might want to just replace it. Are you taking the tension off the front spring before trying to adjust - That really makes it easier!
Old Apr 7, 2005 | 02:37 PM
leaftye's Avatar
leaftye
You can get aftermarket bolts from Hardbar. They're a supporting vendor.
Old Apr 7, 2005 | 02:39 PM
vetteamerica's Avatar
vetteamerica
how do the bolts get replaced?
Old Apr 7, 2005 | 02:42 PM
yellow01's Avatar
yellow01
You'll have to take all the tension off the spring, then back the bolt all the way out and install a new one. I *think* although someone could confirm, you'll have to undo the upper A-arm onthat side to lower the lower A-arm enough to get the bolt all the way out and a new one in.
Even if you don't have to, I can tell you from experience it isn't that difficult and makes things MUCH easier. Torque on those bolts is relatively low so they're easy to torque back up. Just be aware there are washers behind them that need to go back in the correct places.
My advice would be to vice-grip it to where you want, buy replacement bolts, and the next time you have it up in the air for some reason just replace it then.
Old Apr 7, 2005 | 09:14 PM
RunNE1's Avatar
RunNE1
Thanks for the help guys.
Yes I did put another jack on the spring to release tension. It helped out alot on the driver's side, but did not make much of a difference on the passenger side. Maybe the stud is stripped inside the leaf spring? It does look like you have to take off some suspension parts to replace the bolt. I will try again tonite(vice grips please work) and let you guys know how it turned out. Once again, thanks for the help.
Old Apr 7, 2005 | 10:54 PM
corvette dave's Avatar
corvette dave
Run,
Before you start spray some lubricant on the threads.
You have to jack the spring far enough to get the rubber bushing to come unseated from the lower control arm. You will sometimes hear it pop. If not you will need to get something under the bushing and pry it up.
It will seem like the jack is lifting the car. It is. Lift until the bushing comes unseated.
If that does not work get some large vice grips or channel locks and grab the metal part of the bushing under the spring and turn it. It is much larger and will turn easier.
Do not replace the bolt. It will turn if done properly,
I did 2 this weekend. Both cars (4 bolts) turned by hand.
Dave
Old Apr 8, 2005 | 12:32 PM
Fast one's Avatar
Fast one
If you get the bolt to turn and it won't come out then the steel bushing is free in the spring. Check the archives on lowering bolts for the procedure on repair of the steel bushing.
Old Apr 8, 2005 | 12:40 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Originally Posted by corvette dave
Run,
Dave
( I almost did the same thing) I was lucky and had my car up on a lift in my buddies shop, and the passenger side was a tough SOB to adjust so we sprayed some lube on it, waited a few minuets and it was stil tough but we were able to adjust it,,just took some elbow grease to get er done.
Old Apr 9, 2005 | 05:47 AM
RunNE1's Avatar
RunNE1
Good news. Was able to get the bolt to turn. I had to basically lift up the car by the leaf spring to get it to lift off the lower control arm. The bolt was a little easier to turn. Had to use lots of anti-seize and vice grips to start it off. I then was able to use a box end by sort of angling it to catch one of the last few ridges. Had to end with the vice grips again, but it did turn almost all the way up against the spring. So now, the car looks much better. By the way, how long should you wait to let the car settle and adjust again? Thanks
To Stripped lowering bolt...
