anyone have this cam???
Old Apr 7, 2005 | 08:28 AM
KillerJello's Avatar
KillerJello
Default anyone have this cam???
http://forums.corvetteforum.com/show....php?t=1058402
EDIT:
cam specs are .570/.570 251/239
sounds mean, here is gms description
requires the use of 2002 and later LS6 hollow stem intake valves, hollow stem - sodium filled exhaust valves and valve springs . It features .570" intake and exhaust lift, 251 degree exhaust duration at .050" and 239 degree intake duration at .050". Technical Notes:  Center line of intake lobe means M.O.P. or maximum open point, determined across nose of lobe.  Lobe flank is not symmetrical - for best torque set intake to TDC@105 degree and for best poer set intake to TDC@106.5 degree.  Cam timing @ 0.050" tappet lift (timed @106 degrees intake to TDC)  Exhaust opens @ 51 degrees and closes @ 20 degrees with duration at 251.  Intake opens @ 12 degrees and closes @ 47 degrees with duration at 239.
just curious if anyone know about it
Old Apr 7, 2005 | 08:24 PM
KillerJello
ttt
Old Apr 7, 2005 | 10:11 PM
Face's Avatar
Face
Specs are 239/251, not 251/239. IIRC, the member Bink might be using this cam.
Old Apr 8, 2005 | 12:48 AM
KillerJello
sorry thanks for tha correction, yeah i sent him a pm, but i havent heard anything back yet. thanks though
To anyone have this cam???
