My 427N/A has 42# injectors with 60 fuel pressure. I am beginning to
suspect the injectors are too big as we are having difficulty tuning a fuel richness problem. Any input as to proper injector size would be appreciated.
are you sure your ifr table is correct.... I've got some 42lbers on a basically stock engine just because for future mods I'll have the big injectors allready, I've accually got a little bit smoother idle and a tad bit more response.... I'm useing hptuners... what are you tuneing with and are you sure your new calculations are correct??
Blueprinted 36# from RC engineering; flowed at our pressures they are more like 42#'s. More than adequate, at least on my setup (see other threads).
