Re-programming remote control
Old Apr 8, 2005 | 12:11 AM
rolando.reyes's Avatar
rolando.reyes
Cruising
Default Re-programming remote control
I recently replaced the battery on my remote control for my 2000 vet.
Do I need to take the remote to the dealership to get it reprogramed?
It doesn't activate anything. Do I have other options?
Help
Old Apr 8, 2005 | 12:14 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
get next to the car and hold lock and unlock together - after 15 seconds or so it should beep the horn, and you should be all set.
Old Apr 8, 2005 | 01:32 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
This isn't exactly right. If it were, anyone with a vette key fob could be in your car in 15 seconds.
You need to have the key in the ignition and the ignition turned to the on position. Then hold both buttons for ~20 seconds and after you hear te horn beep it's programmed.
Old Apr 8, 2005 | 09:32 AM
rolando.reyes
Cruising
Default reprogrammed remote
Actually the first option worked. Thanks for everyones help.
Old Apr 8, 2005 | 11:09 AM
nmbis2k's Avatar
nmbis2k
I just stood outside the driver's door, and help them both down together. It worked too. Some of my other cars need you to be very close to make it reprogram.
Old Apr 8, 2005 | 11:29 AM
99vert's Avatar
99vert
Cruise-In VI Veteran
Cruise-In VII Veteran
I tried to program mine and it honks all night after i do it. I finally put the key fobs in a metal container and said screw it. I'll wait till i take it in for an oil change.
Old Apr 8, 2005 | 01:53 PM
5 Liter Eater
St. Jude Donor '11
So you guys are programming fobs without the key in the ignition?!? This doesn't make sense at all.
Old Apr 8, 2005 | 02:26 PM
P-Colavette's Avatar
P-Colavette
Default Question....
Does this work on cars running custom tunes ?
To Re-programming remote control
