ABS/TC/AH warning lights???
Old Apr 9, 2005 | 10:07 AM
Lancer033's Avatar
Lancer033
Default ABS/TC/AH warning lights???
I was taking my car in for an alignment this morning and just before I got there, all kind of warnings went off.
service active handeling
service traction control
service ABS
since I was almost there, I just hit the reset button and kept going and got the alignment done. I thought the brake fluid might have been a little low, so I checked that, and it was fine. While the shop had it on the lift, i checked for any leaks and didn't see any.
Hopefully, this is a good sign, but when I left the alignment shop, all of the warnings were gone. I tested the TC, AH, and ABS on the way home, and they all worked fine.
any idea what happened? The only other thing that I can think of is the brake pads on the car are pretty thin, which could trigger the warnings, but shouldn't the warning come back when I restart the car?
thanks
Old Apr 9, 2005 | 10:09 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
may just be one of those things....clear codes and see what happens..
Old Apr 9, 2005 | 10:12 AM
Z11409's Avatar
Z11409
service ABS
thanks
Just hope it is not the brake / abs module going out--big bucks
Old Apr 9, 2005 | 10:14 AM
c5freak's Avatar
c5freak
Did you hit a large bump or cross some railroad tracks just before the warning came up?
This may have triggered it or it may be a wheel bearing/sensor going south.
Been there, done that.
Check for any error codes and write them down. It may be nothing but see if it happens again.
To ABS/TC/AH warning lights???
