My clutch setup/driveline...
Old Apr 9, 2005 | 06:58 PM
Phil97SVT's Avatar
Phil97SVT
Default My clutch setup/driveline...
I have gotten alot of PM's during the last day or so about my driveline. I have had the same setup for the past year or so and have not broken anything since going to the Ram clutch
Driveline:
Fidanza Aluminum Flywheel
Ram Pressure Plate
Ram Dual Compound Disc
McLeod Adjustable Master
Z06 Slave
No Clutch Spring
300m output shaft
3.90s
26 x 11.5" ET streets(11-14psi) 12-12.5 PSI average
Launch:
6000 + 150 shot on a progressive controller
60's:
Best: 1.401
Worst: 1.470
Average: 1.43
Old Apr 9, 2005 | 08:52 PM
rodney@rpmtransmissions's Avatar
0rodney@rpmtransmissions
Former Vendor
What transmission?
Old Apr 10, 2005 | 10:38 AM
Phil97SVT's Avatar
Phil97SVT
Oh yeah,
Rodney prepped M6 and supporting hardware
Phil
Old Apr 10, 2005 | 02:18 PM
JetVette01's Avatar
JetVette01
What size wheels front and rear are you using? Brand, backspacing, offset, etc. Is your rearend built by DTE? Stage 1, 2, 3 ?
Old Apr 10, 2005 | 04:10 PM
Phil97SVT's Avatar
Phil97SVT
CCW 16 x 10 and 16 x 5. My rear-end was built by one of my homies.
Phil
Old Apr 10, 2005 | 09:20 PM
Ranger's Avatar
Ranger
Hey Phil, how many passes do you have on that particular clutch? TIA.
Ranger
Old Apr 10, 2005 | 10:40 PM
Phil97SVT's Avatar
Phil97SVT
Ranger,
I can only guess 75+ passes. This is the same clutch I ran all last year and the end of 2 seasons ago.
Phil
Old Apr 10, 2005 | 10:59 PM
Red C5's Avatar
Red C5
Thanks Phil. Your 60' times are amazing for a stock susp. IRS car.
Old Apr 11, 2005 | 08:56 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Phil, do you run the RAM 980 disk? That is the disk I am running and it seems to be working the best out of anything in my car. I am sort of a afraid to beat on it with some sticky tires though since I dont want to go through any more clutch issues.
Old Apr 11, 2005 | 09:37 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
No diff brace?
Old Apr 11, 2005 | 11:29 AM
Phil97SVT's Avatar
Phil97SVT
Matt,
I orginally had the 980(6 puck), recently switched to a solid disc with dual compounds.
Phil
Phil97SVT's Avatar
Phil97SVT
Originally Posted by 5 Liter Eater
No diff brace?
Wuts a Diff brace
Phil
Old Apr 11, 2005 | 11:58 AM
The One's Avatar
The One
Originally Posted by Phil97SVT
Wuts a Diff brace
Phil
You'll find out.
Old Apr 11, 2005 | 12:42 PM
Phil97SVT's Avatar
Phil97SVT
Please don't take this post as me bragging or boasting. I have found a combo that will slip enough to cushion the driveline. Between the tires, tire pressure, clutch slippage and my driving style it just all works.
Phil
Old Apr 11, 2005 | 12:49 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Phil
2 quick questions...
1. Do you drive it like you hate it like me?
2. Does Rodney have a website?
Thanks!
Ranger's Avatar
Ranger
Phil
That is the magic of running fast times without serious breakage.
Appreciate the info.
Ranger
Old Apr 11, 2005 | 02:29 PM
onfire's Avatar
onfire
Good info. Good post.
To My clutch setup/driveline...
Old Apr 11, 2005 | 02:52 PM
The One's Avatar
The One
Phil
I was playing off your sarcasm. I guess mine didn't go over well. I won't quit my day job.
You're absolutley right about it being a combo/driving style issue. After ~ 250 passes, I pulled my STOCK clutch just for preventative maintenance and my installer could not believe I raced the car on sticky tires with 4K+ launches. This while everyone else was complaining about sticky pedals and clutches that wouldn't last.
I replaced that clutch with a single disk Mcleod that I got about another 250 passes out of and, again, only pulled it because the motor came out.
You and I are proof that you CAN race modded C5s without blowing through trannies and clutches every few passes.
Old Apr 11, 2005 | 03:16 PM
Hardtop01's Avatar
Hardtop01
Thanks!
I can answer the first question for you, because I know Phil, and have watched him race numerous times. Does launching off the rev limiter give you any indication of how the car is driven.
Bruce
Old Apr 11, 2005 | 03:45 PM
Phil97SVT's Avatar
Phil97SVT
Thanks!
Cajundude,
I wouldn't say I hate it but I drive the car hard. You need to call Rodney on this cell phone.
Ranger,
Between the Tire slippage, tire slippage on the rim, clutch slippage and the soft sidewalls of the tires @ 12psi the combo works. I have seen you race and man its amazing...
The One,
Its all cool. You have quite the car on your hands also. Doing those times in a vert is not an easy feat.
Hardtop,
Thanks! We gotta hang out soon....Did I tell you the rev limiter is set @ 7200.
Phil
