LS2 into C5 swap
Horsepower gains will be 0 to none from an Ls2 block to Ls6
C5 is a C5 leave it alone
What a waste of $$ and especialy TIME
besides the fact that the above statement is flat out wrong...what he fails to see is that some of us do in fact enjoy getting our hands dirty in an effort to try something new and different, and if along the way, a hybrid LS2 w/ LS6 heads and cam happens to make 50 more at the wheels than a fresh LS6 replacement...well thats just a bonus. I plan on doing all the work myself on this project (excluding tuning obviously) so the process is as much the point as the end result
now back to the knock sensor issue. If Im correct (which is rare) the problem is that the LS1/6 had knock sensors and the LS2 does not??? If someone can varify, please do. So how exactly would one go about getting around this problem?? Running a motor pushing between 400-500 hp without knock sensors seems like a bad idea to me, but if someone who knows more about the subject than I could chime in, it would be much appriciated.
as far as the cam sensor goes...I believe it was moved to the front of the LS2. Does that mean all that has to be done is to fab up and extension for the stock LS1 harness so that it will reach the front??
I think Ive settled on the LS6 intake/TB based on cost, and the performance numbers Hot Rod magazine got out of an LS2 with that set up. So Im assuming that should be plug and play as well.
Thanks again for all the help guys....and keep it commin
The Cam sensor is at front of motor but the plug and sensor is same as LS1. Just lengthen the harness.
If you go with LS2 intake and/or TB, you have to extend the MAP sensor harness because the MAP sensor is at front of intake. And you also have to reconfigure/rewire the LS1 TB harness to be compatible with the LS2 TB. Shirl Dickey has all this info, as does Andy I believe.
Robert / Gen 3 MS
another thing that MUKAKsC5 doesn't know is that the LS2 has a broader torque curve than an LS6, so it would be a better engine for street driving. The LS6 makes all of it's power at higher RPMs, so you've got to be at the track to really use it. "There is no replacement for displacement"
Just have to make sure you use quality gas and not push it if you start to hear any knock what-so-ever.
This fact would not scare me away from doing this conversion. The upside for power on a reasonable budget is too good!!
Same with the LS2 throttlebody. I use them on C5s all the time. Just use a FAST manifold. (The LS2 manifold blows) 2 wires are not used and the other six are just soldered and heat shrunk to the old harness.
Too bad the stupid pigtail is so expensive. Retail is like $130. That's ridiculous.
The cam sensor wires will have to be extended, and also re pinned. Not only do " A B C and D" do different things, the color coding is different. It took me a little while to figure it out.
The knock sensors will require tapping holes in the block to match. They may need to be desensitized, but probably not.
Remember, audible knock is often not picked up by the sensors anyway. It's at a higher frequency than the sensors are tuned for. I hear cars that rattle like crazy and have no KR.
Just some notes on the LS2. The heads are 01 LS6 heads. They dont even open the chamber to fit the 4" bore. The cam is also an 01 LS6 cam. Just changing to an 02 LS6 cam should be quite an improvement.
They probably did this so that they can bump up the HP in the next model year. That and the fact that they wanted a big difference between the C6 and new Z06 to justify the price.
Bottom line is, I wouldn't be afraid to do the swap. I made the change back in October ( maybe November) just to see if it could be done.
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Andy, thanks for the info, after I have parts in hand I may be calling to pick your brain about a few things since you seem to be ahead of the game on this one
QUOTE]
Horsepower gains will be 0 to none from an LS2 block to LS6?!?!?! Who told you that?!?!!? WRONG.....
The LS2 is an aluminum 6.0L block right out of the wrapper with 4.00" bores vs 3.898" LS6. Inexpensive starting point to mod up a real bruiser LSx motor with more cubes. The LS6 motor requires expensive resleeving to achieve such bore cubes. So, with everything else equal, the LS2 will make more power than the LS6. Yes, the LS6 rated 405hp while the LS2 rates 400hp, but the cam and heads are bigger on the LS6. So, put the LS6 heads and cam in the LS2 block and this hybrid will DEFINITELY make more power than the LS6. More cube's, baby!!!
Ignorance sure is bliss for some here....Not a dig, just keepin it real
Its A no brainer, thats why I went with that route I now have a LS2 402 stroker for my TT. I was going to forge my 98 LS1 and found out that for A few hundred bucks more I could have 54 more CI and A much stronger and better breathing block, the only thing I had to change is the postion of the knock sensors and extend the cam sensor for the new front cover.Oh yea you can still use your LS1/6 PCM on the LS2.
Its not that hard. I was taking apart an A&A 427 this weekend and putting stuff on Andy's new 441cid motor. The knock sensors go right on the side of the block. The cam sensor has to go in the timing cover over the gear. I will double check that with Andy though because he had finished that part before I got back over to watch him. But his 441cid is going into his C6
Next time I have build up a motor for my car it is going to be a 441cid LS2....running the same amount of boost...should be interesting.
I definetly plan to do this block swap in a year or two or whenever the ol'LS1 gives out.
Ls2 4 inch bore ALUM FACTORY BLOCK
accepts Ls1 heads, crank, rods
easily modified for KS use
You can buy LS2 based 402 shorts for under 4K with all forged parts.
Some of the LS1-Ls6 darton resleeved blocks are almost that price for the block alone!
The 4 inch alum block weighs 90-100 pounds less than the 6L iron block equivalent.
There is less piston speed for a given displacement versus a stock bore Ls6 block. You can also run a larger valve without shrouding etc etc with the LS2 as well.
The benefits are HUGE
Without re-sleeve
I'm not a fan of Darton wet sleeve in ls1
Dry sleeve in ls2 not tested ,remember dry sleeves in the Ls1
Next and the best c5r
Ls7 might be great no prices yet.
My .02
John Sr.
