Dynamaxx Help.
Old Apr 14, 2005 | 12:16 AM
Touch of Fast's Avatar
Touch of Fast
Default Dynamaxx Help.
Just installed my Dynamaxx, and now I get some hesitation on acceleration. Feels like the rev limiter kicks in for just a few seconds when i accelerate. Any Ideas!
Old Apr 14, 2005 | 01:01 AM
Vette#2's Avatar
Vette#2
Sounds like you compuer is on a new learning curve. I'd say do a battery disconnect to reboot it. BUT that will lock out your radio, which can cause problems.
MUKAK's Avatar
MUKAK
give CPU a coupple of days to relearn, it will be fine
Old Apr 14, 2005 | 01:14 AM
new vetter's Avatar
new vetter
It does not lock out the radio............
Old Apr 14, 2005 | 10:17 AM
Touch of Fast
Thanks for the help. I'll see if the computer can figure
it out over the weekend. Damn that means I have to drive it all weekend!
Old Apr 14, 2005 | 10:18 AM
CliffB-99's Avatar
CliffB-99
The L and R Oxygen sensors being reversed is a common mistake on installation. Happened to mine. I would start there.
Old Apr 14, 2005 | 10:26 AM
new vetter's Avatar
new vetter
Good thing to check, rears are crossed, fronts are not. Happened to me and it did what you are describing.
Old Apr 14, 2005 | 06:16 PM
Touch of Fast
Thought I was careful not to cross them, but will check tonight and see. Wouldn't be my first mistake, Thanks...........
Old Apr 14, 2005 | 06:20 PM
Touch of Fast
Did you get a DIC Message or was it just the rough running?
Old Apr 14, 2005 | 09:11 PM
new vetter's Avatar
new vetter
It just ran like crap. No codes, nothing showed on a scanner, fuel trims messed up. Sounds like that's it. I did H/C and Dynatech headers at the same time, along with a new computer program to get the car to idle until the a dyno tune. Once it warmed up, it ran fine above 3,000 rpm , got it to the dyno and could not tune it out. Pulled it off the dyno and put it on the rack and sure enough, the fronts were crossed.
Old Apr 15, 2005 | 12:33 AM
Ron Price's Avatar
Ron Price
This may sound silly but make sure that you have turned Traction Control off. Maybe when you start out TC kicks in and is cutting things back to make sure that the wheels don't spin. The first time I got on mine, it cut out and I thought "what the heck?" Then I remembered, turn traction control off and all was well.
To Dynamaxx Help.
