Headlight binding
Old Apr 14, 2005 | 09:10 AM
BlackArrow's Avatar
BlackArrow
Default Headlight binding
My right headlight on my 02 coupe seems to be sticking momentarily when fully open. When I turn off the lights, instead of lowering smoothly, it sticks for a moment and then jerks free and closes. Any ideas?
Old Apr 14, 2005 | 10:49 AM
ELTGuy_C5's Avatar
ELTGuy_C5
St. Jude Donor '05
Sounds a lot like your headlight gear is on its last leg. Chevrolet installed a hard nylon (plastic) gear in our pop-up headlight motors. They don't have a lot of longevity, especially if you use Twilight Sentinel.
If you're under warranty... take it in.
If not...
You can either pay $200-ish for a new motor assembly
or Shop around for a new gear.
http://www.rodneydickman.com/retail.html
He sells replacement brass gears and many here on the forum have used his service. Don't freak out when you see the Fiero logo everywhere. He specializes in Fiero parts but since the headlights are similar for F, Y and P bodies he makes kits for all three.
I have one myself
Old Apr 14, 2005 | 05:05 PM
Dustie's Avatar
Dustie
Default hdlt
Also make sure that the motor/actuator assembly is tight... have read that if it loosens up, even the brass gears can strip.
To Headlight binding
