Tire Pressure - HELP!!!
Old Apr 14, 2005 | 05:05 PM
OOOH TWO's Avatar
OOOH TWO
Default Tire Pressure - HELP!!!
What PSI do you all keep your tires at? I have Yokohama AVS Sports and they say on the side wall that you can put up to 53 psi. I have them at about 45 psi and they just spin like crazy - absolutely no traction, even with traction control on!!! I had MUCH better traction with the stock run flat. Any suggestions other than getting new tires!?
Thanks.
Old Apr 14, 2005 | 05:09 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
start with 30 psi cold - monitor tire wear and adjust if necessary
Old Apr 14, 2005 | 06:18 PM
c5freak's Avatar
c5freak
I've got the same tires. (Yoko AVS Sports) and I never run above 32psi.
I ususlly keep them at 30-31 psi cold tire pressure.
If you put them at 53 psi cold, that pressure is going to be way, way up there when they warm up.
Old Apr 14, 2005 | 07:24 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
That 53 is a MAX safty rating. Thats when the tire will go boom.
30 cold, I have never seen anything else on a passanger car.
Old Apr 14, 2005 | 07:28 PM
PhoenixCIS's Avatar
PhoenixCIS
i normally do 28 cold
Old Apr 14, 2005 | 07:42 PM
EHS's Avatar
EHS
Originally Posted by OOOH TWO
What PSI do you all keep your tires at?.... Any suggestions other than getting new tires!?
Your car may have come with something similar to this:
Or, may even have one of these:
Old Apr 14, 2005 | 11:15 PM
GrayC5's Avatar
GrayC5
Pressures shown on the Tire Loading Information Label on your driver's side door is a good place to start. Monitor the tires for wear and adjust accordingly if needed.
Tire Loading Information Label - 2003 Convertible:
Old Apr 14, 2005 | 11:59 PM
EHS's Avatar
EHS
Reinforce this baby.
Old Apr 15, 2005 | 11:47 AM
OOOH TWO's Avatar
OOOH TWO
Thanks for all the feed back. I'll put them at 30 - 32 psi & see if that helps. I just wasn't sure if different tires required diferent psi - especially going from run-flats to non run-flats. Thanks again!
Old Apr 15, 2005 | 06:06 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I keep mine at 26-28 cold. When they warm up they are right around 30.
To Tire Pressure - HELP!!!
