coolant flow directio
Old Apr 14, 2005 | 05:39 PM
connellyh's Avatar
connellyh
Default coolant flow direction
Which way does the coolant flow in an LS1? From the engine to the top of the radiator and from the bottom of the radiator to the thermostat or the other way around?
Old Apr 14, 2005 | 06:01 PM
Av8ter's Avatar
Av8ter
It goes from the engine out through the thermostat to the bottom of the radiator, then it goes through the radiator, out the top of the radiator and back into the engine and all through the engine and then out through the thermostat again.
Old Apr 14, 2005 | 07:52 PM
ALLEGRO's Avatar
ALLEGRO
LT1 was a "reverse-flow" motor but was not carried over to the LS1/6 due to cost factors.
Having replaced a water pump in my '94 Trans Am GT (LT1) I can understand why!
Old Apr 15, 2005 | 01:27 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Originally Posted by Av8ter
It goes from the engine out through the thermostat to the top of the radiator, then it goes through the radiator, out the bottom of the radiator and back into the engine and all through the engine and then out through the thermostat again.
The thermostat is inline with the lower radiator hose.
Old Apr 15, 2005 | 09:35 AM
Av8ter's Avatar
Av8ter
oopps. That is correct. I had those swapped around. I will edit it.
Old Apr 15, 2005 | 01:22 PM
leaftye's Avatar
leaftye
FWIW, GM and Evans Cooling have been having legal battles about reverse flow cooling for many years.
To coolant flow directio
