codes thrown are?
Old Apr 15, 2005 | 12:09 AM
jeff1surfs's Avatar
jeff1surfs
Default codes thrown are?
On start up my DIC reads tires sensors... I have changed wheels but did not put in the sensors.
It recently began with "service engine soon" and the traction control and ABS lights stay on in the speedometer?
It does disable the traction control, my guess is also the ABS.
I just turned 61k or so.
I ran the diagnostic routine and came up with
U1096 H loss of com. with IPC
U1064 " " " " BCM
U1016 " " " " PCM
C2120 TPM system malfuction (no sensors received)
I am at a loss with what this means. Any help is greatly appreciated.
I do not wish to take it back to the dealer, not after they rang me up for $461 for the replacement of the oil pres. sensor.
Thanks,
Jeff
Old Apr 15, 2005 | 12:13 AM
EHS's Avatar
EHS
Originally Posted by jeff1surfs
....I have changed wheels but did not put in the sensors.
U1064 " " " " BCM
U1016 " " " " PCM
C2120 TPM system malfuction (no sensors received)...
You modified it and now you get codes?
Hmmnnnnn....
I wonder.
It may have something to do with your modifications.
Did you say you didn't put the sensors back, on a car that is set up for sensors?
Hmmmnnnnnnnn....
"loss of comm"
"loss of comm"
"loss of comm"
Three errors like that?
I wonder what the are trying to communicate with -- what could be missing????
Hmmmnnnnnnn.......
Old Apr 15, 2005 | 01:11 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Don't worry about the 3 loss of comm codes atleast as long as they are followed by the letter "H", now if they are follwed by an "HC" then you've got problems. Just hit the reset button and they should clear out.
The only way to eliminate the C2120 code is to have the BCM flashed to eliminate the TPM system or install the sensors back into the wheels.
To codes thrown are?
