Automatic Transmission Shifting Question
Old Apr 15, 2005 | 04:50 PM
MikeN's Avatar
MikeN
Default Automatic Transmission Shifting Question
Recently sold a 2000 Convertible(18,000 miles) with an automatic transmission. Today I bought a 2003 convertible with an automatic transmission(7600 miles).
The transmission on the 2000 had a crisp shift as it went through the "gears" almost a slam feel.
The 2003 has a much more soft shift pattern. Is this an adjustable item through the computer system or do I need to do some transmisssion modifications?
Any help on this would be appreciated.
MikeN
Old Apr 15, 2005 | 05:02 PM
Gimmesum HP's Avatar
Gimmesum HP
The 2000 sounds like it might of had some type of computer tune. But yes you can get your shift points changed through your pcm. Just make sure you let someone who knows what they are doing handle it.
Old Apr 15, 2005 | 09:52 PM
C5magic's Avatar
C5magic
You can also adjust your shift points up or down through the PCM if you think that is needed.
Old Apr 15, 2005 | 10:03 PM
Maniac's Avatar
Maniac
My '98 had a superchips tune loaded when I bought it. I have the tuner in case I want to go back to stock. The shift from first to second is so crisp, it chirps the tires when I get into it. It may be a bit too crisp and I may go back to stock firmness. I guess I went the long way around your question...yep, can be tuned through the computer!
To Automatic Transmission Shifting Question
