How to aim headlamps?
Old Apr 15, 2005 | 08:00 PM
servohead's Avatar
servohead
Default How to aim headlamps?
hey guys, just a silly question here on how to aim my headlamps. They're not modified or anything, just aimed extremely low for some reason.... Thanks for any help.
Old Apr 15, 2005 | 08:10 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I don't have the specs..someone here does but....park about 15-20 feet away from your garage door or wall on a level surface..pull the headlight bezel plugs out and you can see the adjustment screws.... and using a torx screwdriver you can adjust the height with a few turns..I think its a #15 Torx driver.....driving lights are the same way....those damn things are way off adjustment for them is a screw right above the light
Old Apr 15, 2005 | 08:21 PM
servohead's Avatar
servohead
Ok cool, I just went out and found those T-15 screws but the problem is now that they won't turn for me.... is there a lock on it somewhere? Or Is it stuck somehow....
Old Apr 16, 2005 | 07:05 PM
servohead's Avatar
servohead
Ok... So I adjusted one side and went to adjust the other but because it was so friggen tight from never being adjusted I stripped out the T-15 slot! Tonight I'll try again, I spray lubed the adjusters earlier today and hopefully that helps...
To How to aim headlamps?
