catch can owner inside plz...
Old Apr 15, 2005 | 10:29 PM
Xlr8tnC5's Avatar
Xlr8tnC5
Default catch can owner inside plz...
When you installed your catch can did you remove your PCV valve completely? Thanks.
Sorry, forgot to mention I have a amw can and it's a 2003 Coupe.
Old Apr 15, 2005 | 10:54 PM
jrizzuto's Avatar
jrizzuto
No No No, the catch can goes between the PCV and the intake vacuum source. Mine is directional, if yours is too make sure the flow of vacuum is going in the direction it's supposed to. Do a search in this forum or others for pics and diagrams. Hard to describe without a picture.
Old Apr 15, 2005 | 10:59 PM
LoneStarFRC's Avatar
LoneStarFRC
It goes: Out of your valve covers (or valley cover outlet for Z06 owners), to the catch can, then from the catch can to the pcv then to the intake manifold. The choice of mounting the can is yours. I've got mine up front on the inside of the frame rail like Patches'. HTH
Robert
Old Apr 16, 2005 | 12:09 AM
Xlr8tnC5's Avatar
Xlr8tnC5
What do I do with the metal "hose" that is surrounded by a foam sleeve that the pcv valve fits into?
Old Apr 16, 2005 | 12:41 AM
Hall1836's Avatar
Hall1836
Is there something missing from my car. I have only a hose from the valve cover to the throttle body, no PVC. Outlet on the cover is metal hose is about 8 inches long, on the passenger side.
Old Apr 16, 2005 | 12:57 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
I'm with you.
I got so confused that I just threw it in my tool bax and decided that I will have A&A do it along with everything else I'm havin done.
Old Apr 16, 2005 | 09:34 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Thats a breather hose, your PCV hose hooks into the intake manifold behind the throttlebody on the right side.
Old Apr 16, 2005 | 09:37 PM
Racin Z06's Avatar
Racin Z06
Can someone give us a few pictures?
Old Apr 17, 2005 | 12:09 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Old Apr 17, 2005 | 01:17 PM
Hall1836's Avatar
Hall1836
Thanks for the reply re breather hose. Hooked up the catch can by leaving PVC in location on throttle body with line to side of AMW can, and connected 3/8 foam covered line to top of catch can. Thanks, Hall
Old Apr 17, 2005 | 02:42 PM
AFBombdude's Avatar
AFBombdude
That should do it.
Old Apr 17, 2005 | 06:34 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Here is where I mounted mine.
Old Apr 17, 2005 | 09:20 PM
Blueyednd's Avatar
Blueyednd
St. Jude Donor '05
To catch can owner inside plz...
