Lg Long Tubes
Old Apr 15, 2005 | 11:31 PM
355vortechC4's Avatar
355vortechC4
Default Lg Long Tubes
Hey...i just finished with the long tube install on my 02 c5 vert....fit and finish is awsome.
Just wonderin if i should tune the car after the longtubes?
I have hp tuner ready to go....car has bb cat-back,vararam b2 intake,tb,msd wires.
Thanks for any help.
Old Apr 15, 2005 | 11:45 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Of course, if you want maximum gains you should tune after every performance mod. The only issue is cost. Many recommend waiting until all of your mods are complete in order to save costs on tuning. You will be running rich after your headers are installed. You will be able to squeeze out more hp by optimizing your Air/fuel ratio among other things. Enjoy your headers, I love the mean sound.
Old Apr 16, 2005 | 04:23 AM
loudsam's Avatar
loudsam
The good thing about getting it dyno-tuned is you can post the results and we can pick-apart your performance increases and start another heated debate about the virtues of different header brands.
Old Apr 16, 2005 | 08:18 AM
Ruler89's Avatar
Ruler89
Not to mention the manipulation of dyno parameters to produce inflated results.
Old Apr 16, 2005 | 08:24 AM
Mike04's Avatar
Mike04
I gained about 18hp with a dyno tune. I had LG long tube, catbacks, and a vararam. In my pictures it has my dyno run before and after the tune.
Old Apr 16, 2005 | 09:10 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
No debate LG's rule
Old Apr 16, 2005 | 10:22 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
You should have it tuned to get the maximum power gains from the headers.
Old Apr 16, 2005 | 10:49 AM
CNB's Avatar
CNB
That is exactly what will happen.
Old Apr 16, 2005 | 04:20 PM
loudsam's Avatar
loudsam
Here we go AGAIN!
Old Apr 16, 2005 | 04:31 PM
corvettefrance's Avatar
corvettefrance
On my 02 coupe MN6 I installed the LG LT pro with X pipe, no cats, no muffler (straight pipe), the Vararam, and never went for tuning.
I had the the check engine light on since the LG.
My Dyno show 356RWHP and 377RWTQ.
Fllowing this number I'm not sure the dyno that will cost $500 will give me a lot of more. Except removing the check engine light.
The AF ratio is also very good.
Old Apr 16, 2005 | 05:25 PM
zoomn8r's Avatar
zoomn8r
How long did it take you to install the LG's and how much trouble was it?
Old Apr 16, 2005 | 07:05 PM
corvettefrance
I will say 20 hours. I use "LS1 howto" it is great.
The only real problem was to raise the car more than 20".
I lost at least 2 hours to do this and a good hour to have the headers to go through. Except this everything is well documented and easy.
I higly recommend to coat them it will remove some heat especially around the spark plug wires.
Old Apr 17, 2005 | 09:07 AM
Mike04's Avatar
Mike04
It took me about 8 hours working at a normal pace to install them. I have a little experience working on the car though.
Old Apr 17, 2005 | 12:02 PM
corvettefrance
I had no experience working on the engine compartment before on this car.
I had the problem to optain the 20" lift.
I did it in three weeks working 1 to 2 hours at a time.
Thus explain why the total is 20.
If you start early in the morning and have evrything prepare (read LS1 how to 3 to 4 times before)I think you should be able to be done by the evening
Old Apr 17, 2005 | 12:08 PM
vetterlatethannever's Avatar
vetterlatethannever
Cool, congrats on doing it yourself!!
Old Apr 17, 2005 | 02:07 PM
NIGHTMARE...2001's Avatar
NIGHTMARE...2001
I wouldn't bother with the tune for right now. Wait untill you get some more serious type mods before spending those $$, as mentioned above.
Congrats on your install!
Old Apr 20, 2005 | 02:19 AM
355vortechC4
Thanks for the info guys....looks like for now this will be the last mod for the c5....till i can save up doe for a charger.
Im gonna give her a tune this friday and will post up some numbers.
Car runs great with out the tune and sounds INSANE!!!!!!!!!!!!!!!!
To Lg Long Tubes
Old Apr 20, 2005 | 06:04 AM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Congrats! I love mine too and esp the sound and torq below the curve. Same mods here too. My tune didn't make huge gains in peak, but, the gains below where very nice, like over 40FTLBS Congats again!
Dave
Old Apr 20, 2005 | 09:41 AM
nwdanner's Avatar
nwdanner
I just did an LGM install myself, about 3 weeks ago. Best mod yet! I will be having the car tuned at the end of April to get the most gains. If this is your last mod for a year or so then I'd go ahead and get it tuned, if you can swing it.
Here's are my posts regarding my LGM install:
http://forums.corvetteforum.com/show....php?t=1057322
http://forums.corvetteforum.com/show....php?t=1067338
After my header install the car wound up running slightly rich (12.7) and the PCM is detecting detonation (knock;false or not). Because of this my post-header install peak dyno numbers were only 334rwhp/354rwtq. The torque gains in the lower RPMs are awesome however! I'm hopeful that tuning will take care of the knock issues and push me into the 350rwhp/365rwtq range.
Old Apr 20, 2005 | 10:22 PM
DarkForce's Avatar
DarkForce
Funny, I had Lou's guys put mine on, with X-Pipe, Borla 4 tip stingers and the WCC Hurricane ram-air system, and I saw 38 RWHP after tuning (Bull S%^&) and I was extremely lean (around 14.1) so I took it to another buddy of mine (closer to Keller) and we flattened out the dyno results, enriched the air fuel mixture and I actually lost some RWHP, but gained a little torque.
Allot of guys have said the same thing about LG, but all being said, I DO LOVE MY LONGTUBE HEADERS and I wouldn't change the combo I'm running for anything. I think I will stick with my buddy tuning my car from now on though. he doesn't blow smoke up my a$$.
Regards, Bryan
