Trunk hard to open
Old Apr 16, 2005 | 06:02 PM
smooth1's Avatar
smooth1
Default Trunk hard to open
I know there is a service bulletin for '97 models on this, apparently the spring in the latch needs to be changed. However, my 2004 Vert has the same problem: hit the trunk release, and it opens about 1/4", and you need to pry it open from the corners.
So, has that problem been fixed by GM on later models? Anyone else with this snag? Do I just need to adjust my latch height? As always, thanks for your help, luv y'all!
Old Apr 16, 2005 | 06:33 PM
hansenisu's Avatar
hansenisu
St. Jude Donor '10
I do the Fonzie hit on the emblem and it pops up a bit further so you can open it.
Old Apr 16, 2005 | 06:34 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
I'm not sure if you can adjust it or not. Why not just take it to the dealer and let them repair it under warranty. I suppose if you try to fix it yourself, and make the problem worse, it could void that part of the warranty. Might be just a lubrication problem too.
Old Apr 16, 2005 | 06:40 PM
BradSW's Avatar
BradSW
From: From San Diego to Bentonville, AR.....WTF was I thinking?!? Oh yeah, that free state thingy!
St. Jude Donor '15-'16
Had the exact same thing with my 2003 vert. Tried the dealer and their adjustment did nothing. Then I read on this forum to spray some WD-40 on the latch mechanism. Fixed the problem right away. Been nine months and not a problem since.
Good luck.
Brad
Old Apr 16, 2005 | 06:52 PM
DirteeDave's Avatar
DirteeDave
Good luck.
Brad
Worked like a champ for me too!
Old Apr 16, 2005 | 07:15 PM
azmusclecar's Avatar
azmusclecar
Had the same problem, just went out, sprayed lubricant, problem solved. Wish all my problems were this simple
Old Apr 16, 2005 | 08:26 PM
Dr. Dan's Avatar
Dr. Dan
[QUOTE=BradSW] spray some WD-40 on the latch mechanism. /QUOTE]
The latch??? Would have figured the hinge pivot pins, which I did with limited sucess. Now to go out there and try the latch.
Thanks,
Dan
Old Apr 16, 2005 | 08:59 PM
smooth1's Avatar
smooth1
Wow! That simple? Gonna do it 1st thing in the morning. Many Thanks!
Old Apr 16, 2005 | 11:28 PM
Vettlldo's Avatar
Vettlldo
I had the same problem as well. After spraying silicone lubricant (probably leftover breast implants in a can for all I know) down in the latch area, the problem went away.
Old Apr 17, 2005 | 07:58 PM
smooth1's Avatar
smooth1
Thanks to all, it worked like a charm!
Old Apr 17, 2005 | 08:10 PM
Cscokd's Avatar
Cscokd
hmmm...maybe I should have tried some lubricant. I've been popping the latch on my trunk and then shut my car door (windows up) which uses internal air pressure to pop the lid open.
Reminds me of the Blonde joke. She goes to the auto body shop and asks about having a dent removed. The mechanic, busy at the time, told her to just go home and put her lips around the tailpipe and blow really hard. So she went home to give it a try but it wasn't working. Her friend drove up (another Blonde) and inquires what in the world her friend was doing down on her knees blowing on her exhaust pipe. So the first one explained what she was instructed to do but that it wasn't working. The second one says: "Ohhh silly, you have to roll the windows up for that to work!"
Okay...never mind, I'll go get my can of WD-40
Old Apr 24, 2005 | 09:06 PM
VegasRed2001's Avatar
VegasRed2001
Another believer. Thanks for the tip, it worked great.
To Trunk hard to open
