fuel DIC
Old Apr 18, 2005 | 01:22 PM
AndrewNguyen's Avatar
AndrewNguyen
Default fuel DIC
sometimes my gas gauge for the DIC says low for the range, after a full fill up. I am thinking its the sensor going bad and if its an easy fix
Old Apr 18, 2005 | 03:41 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
You either need to reset the AVE MPG or drive around alittle. Also do you fuel up with the car off? The car needs to be cycled on/off for the range to reset also.
Good luck.
Old Apr 18, 2005 | 06:57 PM
servohead's Avatar
servohead
Aaaand, because I'm not sure exactly what gauge you're talking about, IF it's the gas gauge go out and buy a couple bottles of techron fuel system cleaner. Add this to the bottom of the tank for two tanks and your fuel gauge will work normally again. No joke, don't go replacing the sending units just yet!
Old Apr 18, 2005 | 07:09 PM
AndrewNguyen
thanks screw991le and servohead, im off to walmart to buy some of the techron stuff
Old Apr 18, 2005 | 07:14 PM
birch64's Avatar
birch64
Good luck.
takes a few minutes to reset
To fuel DIC
