What does a TC do?
In general you will need a little more RPM get moving when you pull off from a standstill with a high stall T/C. How much extra RPM that is required depends on the stall speed & the design of the converter.
Some of the mild converters (2400-2800 stall) feel like stock if you have 3.42 or better gears.
Will high-stall torque converters shorten the life of your tranny and drivetrain. Yes, most likely they will, just like making more horsepower will, and just like driving aggressively will. Is it a big worry or is failure imminent as soon as the high-stall converter is installed? Not hardly.
Do want you want to do, have fun, and leave the worrying to the feint of heart.
Regarding your original question about what a performance torque converter does............
A high-stall torque converter increases performance in a couple of ways. The first is the obvious one in that it helps you off the line via its higher stall speed and increased torque. The other big advantage provided is what's called “shift extension.” With a high-stall converter when your transmission shifts at WOT, instead of the engine speed dropping down to 3000-3500 rpm, it will stay at 4000-5000+ rpm (depending on the converter) and you'll be right back up to redline again for your next shift. This results in your motor staying in the meat of its power band for the whole run and that translates into improved ETs. This “shift extension” factor will help even if you never visit a drag strip, as it will eliminate the “dead spot” that stock/lower-stall converter cars suffer from. Now when you accelerate and your transmission kicks down into passing gear, instead of your engine having to build up speed from the 3000 rpm range, you'll be starting at that higher engine speed. This translates into better acceleration, better performance, and safer passing.
high stall converter you NEED to also install a trans. cooler. A high stall
will cause higher trans. temps. and thus shorten the life of the tranny.
Oh, also do the trans cooler. Flp explained to me the main reason a4's fail is the heat. The clutch packs get too hot and start to slip. So do the cooler and you will be fine.
