Going to look at a car for forum member tonite, 1999 FRC (I'm 5 minutes away, he's a couple hundred miles away) figure may as well check for any current/history codes. Is procedure the same, that is hold down Options, press 'Fuel' 4 times on a 1999?
Any specific items to check for that 99's are known to be problematic for?
thanks - should be interesting.
The proceedure is the same.
Ignore codes U1016 U1064 and U1096 as they come with most all of the older cars. They are not real indicators of problems, just oversensitive trigger points.
