reset oil change light help
Old Apr 19, 2005 | 06:12 PM
happyhourvette's Avatar
happyhourvette
Default reset oil change light help
need to reset oil change lighe but misplaced books
Old Apr 19, 2005 | 06:31 PM
2KVetteMan's Avatar
2KVetteMan
Turn the key to "on" do not Start engine.
Set the DIC to show the oil life.
Hold Reset, should clear.
Start Car.
Cheers!!
Old Apr 19, 2005 | 07:38 PM
VLVETTE's Avatar
VLVETTE
[QUOTE=2KVetteMan]Turn the key to "on" do not Start engine.
Start Car.
Also instead of hitting reset just pump the gas peddle 3 times
Old Apr 20, 2005 | 10:40 AM
vetdude's Avatar
vetdude
With the engine off, fully depress gas pedal three times.
Old Apr 20, 2005 | 11:37 AM
bowtie911's Avatar
bowtie911
Turn ignition to "ON" position
Bring up oil life display
Press gas peddle three time to floor
This should reset your oil life.
Old Apr 28, 2005 | 06:27 PM
NotRiceAnymore's Avatar
NotRiceAnymore
You guys rule! i've been trying to figure it out for the past 4 days!
Old Apr 28, 2005 | 08:38 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Apr 28, 2005 | 09:02 PM
2KVetteMan's Avatar
2KVetteMan
Didn't know you can reset by hitting the gas pedal. Learn something new everyday with this car.
To reset oil change light help
