upgrading active handling...
Old Apr 20, 2005 | 11:07 PM
b_pappy's Avatar
b_pappy
From: the GOCC are everywhere, even back from "band camp"
Default upgrading active handling...
I just got back from track day at Willow Springs and had a blast! After talking to a few guys about my Traction Control / Active Handling cutting in and out they suggested I put it in competition mode. That would be fine, except 2000's don't have that. So has anyone upgraded? Can the compute be reflashed or something? I'd love to get back out and wear out another set of tires! Any advice?
Thanks,
Bruce
Old Apr 20, 2005 | 11:17 PM
purrvert's Avatar
purrvert
With the car stopped, hold down the Trac control button for five seconds, you will then be in Comp mode.
Old Apr 20, 2005 | 11:41 PM
shurite44's Avatar
shurite44
I don't think all 2000s had comp mode. Anyone else know about this. I am not totally sure but I believe some early 2000s did not have this.
Old Apr 21, 2005 | 12:29 AM
army2000's Avatar
army2000
St. Jude Donor '11
in 98-00 models the active handling was an option, 01+ was standard.
Old Apr 21, 2005 | 12:30 AM
shurite44's Avatar
shurite44
Disregard I am pretty sure I am wrong about this.
Old Apr 21, 2005 | 12:32 AM
shurite44's Avatar
shurite44
So does he have comp mode? I would think if you have AH you probably have comp mode as a function.
Bill Dearborn's Avatar
Bill Dearborn
All the 98 through 00 cars that had active handling could be switched into Competition Mode. For cars with TC only all you can do is switch TC off.
Bill
Old Apr 21, 2005 | 12:33 AM
shurite44's Avatar
shurite44
Bill
phew I am glad that is over with. I got myself all confused for a second.
Old Apr 21, 2005 | 02:45 AM
GrayC5's Avatar
GrayC5
First, your car must be equipped with Active Handling (RPO JL4) in order for you to have the Competitive Driving Mode. If your car is equipped with Active Handling, the button on your console will have the words "Active Handling" above it. Also, your car's RPO label will show the RPO Code JL4. Otherwise you do not have Active Handling.
The 1st Generation of Active Handling made its debut in the 1998 model year as optional equipment. With 1st Generation Active Handling, the car must be brought to a complete stop in order to enable the Competitive Driving Mode. Next, you must press and hold the Active Handling button (approximately 5 seconds) until COMPETITVE DRIVING appears in the DIC. You can read more about the 1st Generation Active Handling and the Competitive Driving Mode using the following link:
Active Handling System (GM Press Release, Fall 1998)
With the 2001 model year, 2nd Generation Active Handling was introduced and it became a standard feature for 2001 and all future C5 model years. With 2nd Generation Active Handling, the Competitive Driving Mode can be enabled while the vehicle is moving. You can read more about the 2nd Generation Active Handling at the following link:
2001 Model Year Press Release - More Agility...
Hope this helps.
Old Apr 23, 2005 | 07:02 PM
b_pappy's Avatar
b_pappy
Thanks, got it. I just wasn't waiting long enough. Now I need to upgrade MDS (my driving skills)
Bruce
To upgrading active handling...
