Question after full exhaust install
Old Apr 21, 2005 | 10:41 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Question after full exhaust install
I noticed a very slight miss at idle and there is definitely a miss at 3k plus when I get on it. Is this a computer issue that would be fixed with the dyno tune? Or did I not seat a damn plug wire incorrectly? I triple checked the wires but I guess its possible I could of goofed one. Other than that, the car sounds sweet!
Old Apr 21, 2005 | 10:45 AM
purrvert's Avatar
purrvert
Had the same problem, cracked a plug. You also may have damaged a wire.
Old Apr 21, 2005 | 11:28 AM
FKING1's Avatar
FKING1
IMO an exhaust by itself should not result in a miss or require a dyno tune. When I did mine the car ran as before installation only faster.
Fred
Old Apr 21, 2005 | 11:32 AM
Cajundude's Avatar
Cajundude
That's what I though as well. I must have a bad seated wire or maybe a cracked plug. I checked all the TR55 plugs, gapped at .55 and torqued to the specs on the box. Brand new MSD wires.
Old Apr 21, 2005 | 12:48 PM
blazeone's Avatar
blazeone
Double check the routing of the O2 sensors. Check the instructions as many guys have got this crossed up on thier install and had misses.
Old Apr 21, 2005 | 01:05 PM
Cajundude's Avatar
Cajundude
Oh yea, those puppies are good. I spent probably 45 min. routing the wires. Driver's side to driver's side, etc. I also ended up unclipping the plug to get a little more length so I could run them back behind the fire shield like stock. I then zip tied all the wires away from the headers. Those starter wires were a beotch to get to but all is away from the LTs.
Old Apr 21, 2005 | 11:21 PM
Cajundude's Avatar
Cajundude
It was a plug wire. I took each one off and put them back and it cured the problem. Will be on dyno tomorrow at 3:00!
To Question after full exhaust install
