10-PCM Codes - P0410 & P1571:Need Help!
Old Apr 22, 2005 | 10:32 PM
gwoods27's Avatar
gwoods27
1st Gear
Default 10-PCM Codes - P0410 & P1571:Need Help!
Ive got a 97 C5 with about 97k miles (freaky..).
The Check Engine lightcame on a day ago. I looked up the codes that came up in Diagnostic Mode.
10 - PCM
P0410: AIR System
P1571: ASR Desired Torque
Not sure how serious a problem this is...was wondering if it was time to change out the O2 sensors or is this a bigger issue.
Old Apr 22, 2005 | 11:08 PM
yellowvette837's Avatar
yellowvette837
St. Jude 15 Year Donor
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
I had the PO410. The issue was water in the air pump. this was caused bymny aftermarket air box. Dealer replaced the air pump. I had to fix the little hose that was letting the water in.
Sorry I do not know abour P1571.
Good Luck
