help a guy out
Old Apr 22, 2005 | 10:36 PM
wrustywrench's Avatar
wrustywrench
Default help a guy out
I need the torque numbers for the lug nuts and the brake caliper bracket bolts.....thought it be quicker askng you guys then looking them up
Old Apr 23, 2005 | 02:19 AM
GrayC5's Avatar
GrayC5
Lug nuts for OEM wheels is 100 lb ft. If you have after market wheels, you should check for the manufacturer's recommendation. I tighten my lug nuts in a star pattern in stages, generally starting at 50 lb ft, then 75 lb ft and lastly 100 lb ft or whatever the manufacturer recommends.
Torque for the caliper mounting bracket bolts is 125 lb ft.
You might like to add the following link to your favorites: C5 Torque Specs
Old Apr 23, 2005 | 09:25 AM
wrustywrench
thanks a bunch,, I have them printed out, but coulnt find it..now I have them saved. Just wanted to be sure
To help a guy out
