Electrochromic mirror
Old Apr 23, 2005 | 11:36 PM
dyos's Avatar
dyos
Default Electrochromic mirror
I recently purchased an electrochromic mirror off of ebay for my '98 Vette. I was thinking that one of the four wires to my existing mirror would lose power when the car was off. However, I've found that this is not the case. There are 4 wires Black, Brown, Orange, and Orange. When I connect my volt meter to the black ground wire and either one of the orange wires I get a 12v reading whether the car is on or off. There is also a brown wire but it reads like .07v or something weird like that. Does anyone have the schematics or no what I could be doing wrong? Thanks, any help would be appreciated. I hope I don't have to run another wire from the stupid fuse box just for this.
Jeremy
MCSE MCSA CCNA
http://www.N2NetworkSolutions.com
Old Apr 24, 2005 | 04:31 AM
white90conv's Avatar
white90conv
http://www.c5forum.com/diy/electro_mirror.php
This site gives instructions for installing the mirror on an older c5. I did it on my 2000 with no problem. You need a connector which is listed in the site and I got from Fred Beans.
Old Apr 24, 2005 | 08:48 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
if you want the map lights to come on when the doors are opened (like the stock mirror) then you will need to wire in a relay.
Old Apr 24, 2005 | 01:55 PM
white90conv
I did not need any relay on my 2000 when installing the mirror. Everything works as it did before plus the electrochromic feature.
Old Apr 24, 2005 | 03:27 PM
donnyonee's Avatar
donnyonee
whats the benifit of the new mirror vs the old mirror?
Old Apr 24, 2005 | 06:12 PM
jdmvette's Avatar
jdmvette
Night Owl for life
auto-dimming & led lighting vs. incandescant bulbs.
Old Apr 24, 2005 | 08:19 PM
donnyonee's Avatar
donnyonee
auto dimming? how does that work?
Old Apr 25, 2005 | 01:45 AM
white90conv
At night, the mirror has a dimming feature which is about the same as tilting the mirror with a lever in a conventional mirror. Is this a major advantage? Probably not. But it works well.
Old Apr 25, 2005 | 03:18 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i dont have one myself, but i believe when a car with bright lights gets behind you, the mirror senses the light and dims it the way the lever would on a conventional mirror.
Old Apr 25, 2005 | 12:21 PM
dyos's Avatar
dyos
Yea that's exactly what it does. It has a sensor on the front and a sensor on the back. The one on the mirror side will determine if there is a car with bright lights on behind you and the mirror will turn itself dark blue. The sensor in the back determines if it is day time or night time.
Old Apr 25, 2005 | 10:52 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
If the mirror is an OEM mirror, no relay is needed. I've read that some aftermarket mirrors DO require a relay.
Tom
Old Apr 26, 2005 | 04:19 AM
C5 Frederik's Avatar
C5 Frederik
Using this very good write up (mentioned above)
I changed mine a year ago. Works perfect with all features.
Frederik
Old Apr 27, 2005 | 02:55 PM
RPOZ4Z's Avatar
RPOZ4Z
Tom
yes, that's right.
mine is aftermarket.
Old Apr 27, 2005 | 07:29 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Did this mod, very easy and the best non-Hp mod.
The link to the DIY from this site is dead on. You need the new Harness. The mirror works when the lights are on. The map lights work at anytime. The nice orange mood light also works only when the lights are on. Follow the wiring change in the DIY and you'll have no problems. PM me if you need more help.
To Electrochromic mirror
