What code numbers are you receiving? You may have your front 02 sensor connections crossed. Ensure the wiring is going left to left, and right to right. Also, check the two ground connections. Good luck.
I dont think they could be crossed. I took special care to prevent that, and I marked them. Everything has been fine, but just recently this started happening.
im getting p1133 and p1153....insufficient swithing bank one and two....any ideas? ill check the fuses like you suggested. what is insufficient swithing bank?
