Noobie E-brake question
Old Apr 24, 2005 | 03:39 PM
cheez22's Avatar
cheez22
Default Noobie E-brake question
How hard is it to adjust the emergency brake cable (tighten it)? When I pull it up all the way it still rolls unless I put it in gear. Is this something I can do or do I have to bring it in? By the way, its a 2001 convertible. Is this a common problem? Sorry for all the questions.
Thanks in advance, --Kevin.
Old Apr 24, 2005 | 03:48 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
You need to pull your rotor to adjust teh e-brake...but once you get the rotor off it's pretty easy.
I'm sure there's directions online on pulling the rotor it's been a while since i've done it.
Chris
Old Apr 24, 2005 | 05:00 PM
MSGvette's Avatar
MSGvette
Hope this helps.
http://www.corvetteforum.com/techtip...=158&TopicID=1
Old Apr 24, 2005 | 09:54 PM
cheez22's Avatar
cheez22
Originally Posted by MSGvette
Great step-by-step link. Thanks a bunch.
To Noobie E-brake question
