Suspension?
Old Apr 24, 2005 | 11:15 PM
pewterwest99's Avatar
pewterwest99
Default Suspension?
My '99 coupe is riding really rough. I had a mechanic check out springs and struts and I was told all is OK. I now feel every bump in the road. What could this be? the rear-end doesn't stay planted on take off, and when I hit a bump it feels like I'm hitting a curb.
SOMEBODY PLEASE HELP ME!!!
Old Apr 25, 2005 | 04:05 AM
78Vette-SA's Avatar
78Vette-SA
Dumb question but how much air do you have in the tires? I run about 30lbs.
Did this just start doing this or did it always do it?
Old Apr 25, 2005 | 10:13 AM
jimcork1's Avatar
jimcork1
Do you have ride adjustable suspension?
Also have you bounced the rear to see if the shocks will stroke?
Old Apr 25, 2005 | 10:32 AM
pewterwest99
Depending on Air Tepmature, My tires will hold at 29psi-32psi.
I Have the 3-way Ride adjustible F45 Suspension and the System works properly,( I normally keep it on tour mode and when I switch to sport or perf mode ride quality changes like it should).
I have Pushed down on every part of the car to make sure that the shocks were working properly and they seem to be.
This problem started happening about a month ago and it has gotten progressively worse and I can't figure out what is causing this problem so I can't find a solution.
Hopefully somebody can help me.
Thank you
Old Apr 25, 2005 | 10:43 AM
WKMCD's Avatar
WKMCD
Just a guess but it happened to my 98 vert. Check the bushings for the rear spring. These are the bushings that the "lowering bolts" go through. There is a pad on the bottom and 2 bushings on the top of the lowering bolt. My $.02.
Good Luck!
Old Apr 25, 2005 | 10:57 AM
pewterwest99
Thank You I will check That.
To Suspension?
