Convertible top lid release does not work electrically
Old Apr 25, 2005 | 11:23 PM
sam98c5conv's Avatar
sam98c5conv
4th Gear
Default Convertible top lid tonneau release does not work electrically
Hi, I have a 98 Vette convertible. Hope someone can help. When I press the button to release the top lid the windows go down and the lid does not pop open. When, I give the latch motor direct power, it works, so the motor is not bad. My car is an automatic and I dont believe the E-brake has to be up (tried it). Anyone have any ideas of what can be wrong. Thanks
Sam
Old Apr 25, 2005 | 11:30 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
If your deck lid is unlatched it won't work.
Old Apr 25, 2005 | 11:34 PM
sam98c5conv
4th Gear
deck is closed when I hit the button.
Old Apr 26, 2005 | 08:58 PM
Dr. Dan's Avatar
Dr. Dan
Check your trunk lid. Make sure that it is closed securely. Remember they won't open together.
Old Apr 27, 2005 | 02:06 PM
white90conv's Avatar
white90conv
I have a '00 and went out to see what happens. When the trunk is open and I hit the cover release switch, the cover does not release and the windows do not go down. I also get some chimes.
The release switch actually connects to the body control module which in turn release the cover (through a relay) and rolls down the windows. It sounds like your problem is either in the BCM or in the wiring between the BCM and the relay or in the power to the release relay.
For my '00, I located the schematic. There is a fuse in the folding top cover (tonneau) circuit. It is labelled in the schematic as "TONN REL MiniFuse 17 10A" This appears to be located in the Instrument Electrical Center which is, I believe, under the passenger footwell. The fuse is at the center-left, of the panel. Don't forget, all this info is for an '00 and may not apply to your car.
Old Apr 29, 2005 | 05:40 PM
sam98c5conv
4th Gear
Thanks for the tips/detail. However, I already checked the fuse and relay and all is good.
To Convertible top lid release does not work electrically
