Blackwing Cleaning??
Old Apr 26, 2005 | 02:35 PM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
Default Blackwing Cleaning??
Any advice on cleaning procedure for the Donaldson Blackwing??
Old Apr 26, 2005 | 03:11 PM
J. Nguyen's Avatar
J. Nguyen
Hmm... Good question..
I would like to know this too.. Since I've never cleaned mine yet either.
Old Apr 26, 2005 | 03:19 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
If you have a K&N type cleaner, that will suffice.
Basically, you want to spray on the cleaner, uses a light brush to get any thick residue off the filter. Spray with water, don't use a high pressure as you can damage the filter, liberally spray the cleaner and water. Let 'er dry naturally, don't use any heat or air dryers and then spray with a liberal amount of oil which should be provided in the kit.
Old Apr 26, 2005 | 03:22 PM
flipm's Avatar
flipm
I would also recommend doing this at night and letting the filter drain the oil away away. I rested mine on its nose and noticed that the "liberal amount of oil" I put on may have been too much, because some dripped away.
This helps avoid problems that could be caused by the oil getting on to the MAF....
Old Apr 26, 2005 | 04:21 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Clean Me
________________________________________ ____________________
[J. Nguyen]Hmm... Good question..
I also have a blackwing, after 2 years it's still in the green. It's a micro fiber filter, I have read that you can clean it with "simple green" and water. Hang out to dry, and reinstall. I'm not sure about spraying it with oil, I don't think it's neccessary. BUT....I could be wrong
Old Apr 26, 2005 | 05:56 PM
magredZ51's Avatar
magredZ51
Default filter cleaning.
spray hose from the inside of the filter. Do not over oil.
Old Apr 26, 2005 | 06:21 PM
Special K's Avatar
Special K
You are wrong. Oil it!
Bob
Old Apr 26, 2005 | 06:28 PM
LoneStarFRC's Avatar
LoneStarFRC
This is very good advice. Easy on the water pressure though. Just a nice stream is all that's needed. Done mine twice now. Also, it is very easy to over oil. If you think you may have over-oiled, you can stuff a bunch of clean white cloths into the inside of the filter and let it sit overnight (or at least a few hours). Try to make as much surface area contact with the clean cloth as possible. What you want is a nice even blue color that is not wet. HTH
Robert
Old Apr 26, 2005 | 06:54 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
you need to buy the official cleaning kit for the blackwing. any vendor who sells the filter can get you a box. instructions are included!
Just did mine last week. car runs nicer!
Old Apr 26, 2005 | 06:59 PM
Special K's Avatar
Special K
And I would add one more piece of advice. Don't wait for the indicator to tell you when to service it. Do it once a year or more if you're in a dusty climate.
Bob
To Blackwing Cleaning??
