Compass Mirror?
Old Apr 26, 2005 | 08:47 PM
69's Avatar
69
Cruise-In VI Veteran
Default Compass Mirror?
Hello All,
I have a 99 and I want to retrofit a rear view mirror with a compass. Has anyone done this, suggestions as to replacement mirror brands and wiring tips?
Thanks,
Kevin
Old Apr 26, 2005 | 09:17 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
________________________________________ ____________________
[69]Hello All,
Thanks,
Kevin
The mirror from a C6 can be fitted to your C5. There was a thread posted here on the forum a few months ago. I believe you have to purchase a harness from your local GM parts dept. to make it work.
Old Apr 26, 2005 | 09:32 PM
69's Avatar
69
Hello, I tried the "search" and got no hits......
Old Apr 27, 2005 | 07:40 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Yes, I installed an electrochromatic compass mirror on my '98 about 3 years ago. Believe it was a Donnelley mirror (do a search for their website.). You'll need a new harness w/ a relay built into it. Sorry, I can't remember which vendor I bought it from. The install takes about an hour. It works great--I really like it...Good luck.
Old Apr 27, 2005 | 10:16 AM
mowrey96's Avatar
mowrey96
http://www.c5reations.com/c5.php
click on the self dimming mirror link. this mirror has a compass. good luck.
Old Apr 27, 2005 | 04:44 PM
6SPD98's Avatar
6SPD98
[69]Hello, I tried the "search" and got no hits......
Try This......http://www.c5forum.com/diy/electro_mirror.php
Old Apr 27, 2005 | 05:15 PM
BSiegPaint's Avatar
BSiegPaint
Donnelly is probably the best bet, with Gentex close behind. If you don't get a factory mirror, you will need to get a relay and harness to change your negative trigger light to a positive trigger (or vice versa...). This just means that your lights will go on when the doors open and everything will work as normal. I have the relay and harness you need, but I'll be darned if I can find the instructions I used when I put one of these in my old '99...
Old Apr 27, 2005 | 07:39 PM
BiggieBoy's Avatar
BiggieBoy
These install instructions are fine IF you're installing a late year C5 mirror into a older C5. However, if you go w/ the Donnelly or Gentex mirror, as BSiegPaint has noted, you'll need the relay equipped harness for your interior lights to work. Good luck...
Old Apr 27, 2005 | 08:15 PM
Flying Ace's Avatar
Flying Ace
St. Jude Donor '05-'06
Is the late model C5 mirror a "gentex"??
If so, what is the Gentex number? I see a lot on ebay but am not sure which one it might be.
To Compass Mirror?
