If I understand correctly, an 02 z06 MAF has the IAT sensor incorporated into it. Can I install this MAF on my 98 and is there a pigtail connector that someone sells to facilitate the swap?
97-2000 use a 75mm and is the same as 98-02 F-body
01-04 LS1 and 01 LS6 are the same sensor 85mm screened.
02-04 LS6 is also 85mm but with no screen. Bascially the identical sensor with no screen.
You need a pigtail adapter to plug it in. casper's electronics sells them. But, it really wont be the correct calibration for your car. You should have the PCM recalibrated.. or buy a calibrated sensor like SLP or Pace Parts sells...
