I got this message today for the first time, it just stayed on the screen for about 2min, than said warming up complete. Has anyone else had this happen?
Has happened to me a half dozen times in the last year.
I don't think it's abnormal and have heard other Forum guys with the same experience.
Maybe someone will chime in with what technically is going on as it is in the "warm-up" state.
Scott
Ok I used to know what caused this, but I am a little foggy on it so please feel free to chime in. I believe if you start driving in a turn the active handling needs you to go straight for a certain number of feet, so it will flash this warning until you have complied with its parameters.
It happens whenever you first start driving and are making a lot of turns in the same direction, for example in a parking ramp. It is normal and goes away after you drive for a few minutes in a straight line.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Happened to me just last week. Like you, I was not only surprised to see the message, but I had no idea what it ment. Thanks to the forum members for the info.
I had read on here that it sometimes comes on when you go very slow for an extended time. It has happened to me twice and both times was when I was driving thru a park going around 10 mph or so. In just a few minutes I heard the chimes going off and it said warmup complete.
I see it occasionally. Sometimes after the car has been warmed up already and it was shut down for just a few minutes which makes me believe it has to recalibrate itself. As mentioned above after a few turns then it comes on when the car is going straight. Maybe it should say "active handling recalibrating"
