HELP, service column lock issues
Old May 2, 2005 | 06:36 AM
bowtiebubba's Avatar
bowtiebubba
Default HELP, service column lock issues
Yes, i did read the above sticky. Now to my problem. I have a 2002 mn6 which recieved a recall. I took it in about 6 months ago for the recall and was told by the dealership that they had to have a special tool for the fix,which they would have to order,havent heard from them since.
Okay, had to take a trip to illinois over the weekend and got about half way there and the dic shows service column lock, the column never did lock even when the car was turned off. Car ran like normal the whole trip.
Anybody tell me whats going on? What i need to do?
Appreciate any info you can offer. Thanks guys.
Old May 2, 2005 | 08:06 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Ok, stupid question since you didnt say....did you buy the car new?? If not when you turn the car off can you turn the wheel and lock it?? If not then you may have a CLB already installed.
Old May 2, 2005 | 03:28 PM
bowtiebubba
No, the car was not new, but it was only 6 months old and they had not done any recalls then. The column doesnt lock when the car is off and the keys out either.
Old May 2, 2005 | 03:57 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
If the column is unlocked...and stays unlocked after shutting it off and pulling the key out, you can still drive it without fear.
I drove mine for about a year that way and enjoyed the fact the column never locked (other than having to reset the message at startup).
What likely happened, is when you started it, the column physically unlocked, but for whatever reason, the unlocked feedback signal wasn't received by the BCM. Thus, the BCM became "confused", threw the "sevrice column lock" message, and as long as it remains in this state, no longer attempts to actuate the lock mechanism.
To fix it, go in the fusebox under the passenger floor, pull fuse #25, wait a minute, and reinsert it. That will reset the BCM and all should be back to normal...the message shoud go away, and your column should physically lock again when you remove the key from the ignition switch.
If that works for you, I would strongly suggest investing in a Column Lock Bypass (CLB) to prevent any future problems....next time you might not be so lucky and have it stick in the locked position....then you're stranded.
Although you had the recall service performed, realize the M6 recall procedure does absolutely NOTHING to actually address the lock mechanism. It's intent is to only prevent operation of the car if the lock is physically locked.
Old May 2, 2005 | 09:46 PM
bowtiebubba
Thanks for the help, i appreciate it. I think i will do the fuse thing and then invest in a column lock bypass. Thanks again
Old May 3, 2005 | 02:16 AM
Cscokd's Avatar
Cscokd
The advice given was right on the money. You might want to order your CLB now and not reset your BCM until you receive and install your new CLB. Best of luck to you.
Cheers
John
To HELP, service column lock issues
