Steering Wheel Shimmering
Old May 2, 2005 | 03:28 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Default Steering Wheel Shimmering
Bought a set of CCW505as a few months ago. I have only driven the car once since then for about 1.5 hours on the highway. At around 60 mph plus there is a slight shimmering of the steering wheel. It feels as though it is shaking back and forth (not excessively, but enough to notice). At the time I thought this was merely an alignment problem, but I read someone else's post that complained about the same problem and discovered that the wheels were not balanced properly. Could this be the case? If so, how can I tell if the wheels are not balanced properly? It never crossed my mind that this could be the case because I ordered these wheels direct from CCW (i expected some sort of quality control considering 5g's were spent). thanks to everyone in advance.
Old May 2, 2005 | 03:41 PM
DickieC.99's Avatar
DickieC.99
I find it hard to believe that CCW didn't balance the wheels correctly. I had nothing but good experience with them and have only heard the same. Then again, mistakes can happen. How many miles on the car? You lower it? Checked the alignment yet? I would first have your alignment checked. Good luck, let us know what you find.
Old May 2, 2005 | 03:56 PM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
No, the car is at stock ride height. 30,000 miles on the car. Any chance there could be a broken wheel bearing? The car was riding perfectly fine before the wheel swap. I havent had the alignment checked yet. I was planning on lowering it and then realigning. I find it hard to believe the wheels are not balanced properly as well considering they use the latest hunter machines. Could one of the tires be bad?
Old May 2, 2005 | 04:59 PM
6 Kids's Avatar
6 Kids
St. Jude Donor '06
Its all in the balancing. Take it to a good shop experienced with aftermarket wheels and request a 0 balance.
Old May 2, 2005 | 06:44 PM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
It just seems unlikely. I talked to John and he mentioned that there may be a defect in one of the front tires. Any truth to that?
Old May 2, 2005 | 07:15 PM
NoNeck's Avatar
NoNeck
I just had two brand new Toyos replaced as they were out of round. The condition is called "Radial runout" from what I understand. It does happen. The guy where I had them mounted at my local Goodyear said he sees it in about 1 out of a hundred tires. What threw me was that the shake came and went. It did it at different speeds and sometimes not at all. Usually if the whell/tire is unbalanced it will shake at the same speed all the time from my experiance. It is also possible that if they used adhesive weights to balance your tires, one could have fallen off, throwing your balance job off.
Old May 2, 2005 | 07:47 PM
Wah's Avatar
Wah
Did you remove the washer-like retainers on the rotor hats ?
Old May 2, 2005 | 08:07 PM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
yes they were removed by a prior owner
Old May 2, 2005 | 08:46 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
Maybe the previous owner didn't come clean about the issues he was having?
Old May 2, 2005 | 09:41 PM
2002magred's Avatar
2002magred
Default CCW's 505a's
I just bought a set of 505a's from west coast corvette. All four tires were out of balance. I think I might have a bad tire in the left front. I lowered the car and don't have the ride height right. After getting it right I will have the car aligned. Then I will see if the shimmy goes away.
To Steering Wheel Shimmering
