What spark plug do u recommend?
Old May 4, 2005 | 08:26 PM
cody2275's Avatar
cody2275
Default What spark plug do u recommend?
Can someone give me some info on what brand of spark plugs I should put in my 98 C5?
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I use the Bosch Platinum +4
Old May 4, 2005 | 08:35 PM
CarsRFun's Avatar
CarsRFun
ngk tr55
Old May 4, 2005 | 08:56 PM
Mallory's Avatar
Mallory
I like Brisk plugs. They did a great job in the Cobra.
Old May 4, 2005 | 08:59 PM
Originally Posted by CarsRFun
ngk tr55
Those will be the ones I put in mine when the time comes.
Old May 4, 2005 | 09:36 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
NGK TR-55's
plus they only cost about $1.30 ea.
Old May 4, 2005 | 09:56 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
...and some hot wires...
Peace
Willfulone
__________________
..................Click for
Old May 5, 2005 | 01:21 AM
Lancer033's Avatar
Lancer033
NKG TR55 & MSD Wires
Old May 5, 2005 | 09:39 AM
Steve-H's Avatar
Steve-H
Default NGKs
iridium and platinum are a waste of money. platinum is a very poor conductor so material transfer from electrode to ground is reduced for longer life But performance is not near what an iron or copper plug (NGK) will be.
Old May 5, 2005 | 09:51 AM
MHVette's Avatar
MHVette
I run the same setup!
Old May 5, 2005 | 10:25 AM
92dreamin's Avatar
92dreamin
NKG TR-55'S. Installed some the day before yesterday. Accidentally cracked the porcelain putting one in. I had a miss at higher rpms. Found the problem, now she runs great. Smoother idle. Also tossed in a zip tie mod as well, the car seemed stronger by the butt o meter. The air intake hole in the stock housing is ridiculuously small. It looks designed to restrict air.
Old May 5, 2005 | 11:30 AM
Patman's Avatar
Patman
NGK TR55s are definitely the way to go, but make sure you gap them at .050, not .060. It will give you much better throttle response, and better low end torque with the lower gap. (trust me on this one, I've been playing around with all kinds of different plugs and different gaps ever since I got my first LS1 powered vehicle back in 1998)
Old May 5, 2005 | 03:20 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have Bosch +4 Plats and have no complaints, car runs smoother at Idle IMHO.
Old May 5, 2005 | 04:37 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
Bosch Platinum +4
Old May 5, 2005 | 05:26 PM
shurite44's Avatar
shurite44
Me too
Old May 5, 2005 | 06:38 PM
C5XTASY's Avatar
C5XTASY
Originally Posted by devo
Bosch Platinum +4
I, too, was running the +4's and the car ran great. I'm switching to LS6 heads, along with a new cam, longtubes, etc., and am now going to use Delco 41-985 Iridiums (factory recommended), as Bosch has no recommended plug for the LS6. I thought that very strange.
Ed
To What spark plug do u recommend?
