traction control
Old May 5, 2005 | 01:55 PM
ronniep's Avatar
ronniep
Default traction control
If You wanted to disconnect the traction control how would You do it ?
Old May 5, 2005 | 02:03 PM
123Gone's Avatar
123Gone
Do you really mean disengage or disconnect?
Old May 5, 2005 | 03:26 PM
TalonDG's Avatar
TalonDG
If the issue is that the car keeps turning the TC back on again every time you turn it off, we make a product that solves that problem.
http://www.accuratetechnologies.com/...rcategoryid=18
It's called the "TracMem" and it basically makes the TC control button "sticky". The TracMem remembers the state of the TC button and resets the ECU to the proper mode whenever something else tries to change it.
This turns out to be trickier than it sounds... it involves listening to the vehicle communication bus and paying attention to TC system commands.
DG
To traction control
