Differential Mod
Old May 5, 2005 | 05:16 PM
BAD Z06's Avatar
BAD Z06
Default Differential Mod
I'm thinking of upgrading my differential to 3.90 or 4.10..but does this mod require anything else..or is it a simple bolt on???
Thanks for any help!!
Old May 5, 2005 | 05:19 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
our differentials are very different than the straight axels in the F-bodies...a little bit more work...no modifications just a good installer to build the diff for you otherise it will howl.
Chris
Old May 5, 2005 | 05:23 PM
shurite44's Avatar
shurite44
You will need to reprogram the PCM I believe.
Old May 5, 2005 | 05:43 PM
BAD Z06's Avatar
BAD Z06
Ah yes.. i have heard that...thanks
Old May 5, 2005 | 06:16 PM
BAD Z06's Avatar
BAD Z06
Old May 5, 2005 | 06:38 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
You will only need to reprogram if you have an A4. Texas Auto Gear located off of I45 a little North of downtown are excellent builders. They will charge $250 if you bring them the differential. They build for pretty much all of the Houston shops when it comes to the C5.
Old May 5, 2005 | 07:00 PM
BAD Z06's Avatar
BAD Z06
hell yeah!! thanks!
Old May 5, 2005 | 07:30 PM
BAD Z06's Avatar
BAD Z06
just called them...$1150 for 3.90!!..and no core charge since theyre local...hell ya!
Old May 5, 2005 | 08:51 PM
STA-BLK's Avatar
STA-BLK
Ive never seen a shop do it this cheap.They will install a diff for 250.Thats worth the 8 hour drive just to save the ching(800) that gm quoted me.
Old May 5, 2005 | 09:31 PM
Cajundude's Avatar
Cajundude
They will put the gears in the diff for $250, the R&R is $450.00. Sorry for the confusion.
Old May 5, 2005 | 09:39 PM
STA-BLK's Avatar
STA-BLK
Still gm wants 800 bucks.Id still make the drive.
Old May 5, 2005 | 09:41 PM
Mike Mercury's Avatar
Mike Mercury
you guys are soooo lucky to have a local shop that's experienced with the unique C5 carrier.
I envy you - BIG TIME
Old May 5, 2005 | 10:02 PM
BAD Z06's Avatar
BAD Z06
yes. it is true. we are blessed
To Differential Mod
