LS6 for LS1 Swap
Old May 5, 2005 | 09:20 PM
Minkster's Avatar
Minkster
Default LS6 for LS1 Swap
If I were to swap my stock 2000 LS1 for a crate LS6, use the original MAF, TB, LS6 manifold, original ECM, would it work, or would I be tripping codes and have emissions problems?
Old May 5, 2005 | 09:43 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Car will run fine. No codes.
You might want to have the PCM tuned to get the most out of your setup..
Old May 5, 2005 | 09:48 PM
Tino's Avatar
Tino
Is the LS1 stock computer settings the same as the LS6 computer?
Tino
Old May 5, 2005 | 10:06 PM
Minkster's Avatar
Minkster
Can you run the original injectors or do you need to Z06 injectors?
Old May 5, 2005 | 11:00 PM
vetred's Avatar
vetred
Brother if you know what your doing thats great! But If you dont get someone that DOES
Old May 6, 2005 | 01:03 AM
Minkster's Avatar
Minkster
Just looking for info, not insults.
Old May 6, 2005 | 01:10 AM
Tsab's Avatar
Tsab
It should be pretty much "turn key"......may require some tuning.
Old May 6, 2005 | 09:58 AM
Heretic's Avatar
Heretic
If all you want is a stock LS6, then procure a tuning package, and transfer the settings from a LS6 calibration. I'd use the LS6 MAF and injectors.
Old May 6, 2005 | 01:33 PM
C5XTASY's Avatar
C5XTASY
The 1999 & 2000 C5 (yours) used 26.2 lb injectors. 1997, 1998 and all 2001-2004 LS1's (C5's) and LS6's (Z06's) used 28.8lb injectors. To my 2000 C5, I'm adding a Comp Cam, LS6 heads, 2001+ intake manifold (LS1 and LS6 were the same), Supermaxx longtube headers w/high flow cats and X-pipe followed by an LS1 Edit tune. I am installing the later 28.8 lb injectors. I believe the duty cycle would be awfully high on the stock 2000 injectors, though some have successfully used them. I just wouldn't want a failure (causing an extreme lean condition at WOT).
Ed
Old May 6, 2005 | 02:04 PM
Minkster's Avatar
Minkster
Thanks for all the good info!
To LS6 for LS1 Swap
